Go Back   Tahoe Forum - Chevy Tahoe Forum > 2007 + Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > Technical write ups & Installation Guides
Register to remove these ads.
Technical write ups & Installation Guides This forum is designated to post technical "how to" install guides to assist others with modding thier Hoes
Reply
Thread Tools Display Modes
Old 09-24-2006, 12:05 AM   #1
Gapp
Gapp is on a distinguished road
Default How to: Install of Eibach Pro kit (non auto ride)
This install took me about 3.5 hours and was somewhat involved. A friend to help is a must to make it go smoothly. Here's what you need to do it:
1. Hydraulic jack, stands, and wheel chocks
2. Air compressor (optional, but it will go 2X faster)
3. Spring compressor (You can get at any auto parts store)
4. 21mm deep socket
5. 18mm deep socket
6. 15mm deep socket
7. Pry bar or something for leverage
I opted to do the rear first so you will need to chock the front wheels and loosen the lug nuts slightly on the rear wheels.
Next, position the jack under the rear differential and jack the truck up until the rear wheels are off the ground a couple of inches. Place the jack stands under the frame rails, then drop the weight of the truck onto them, making sure they are level and secure.
Now, remove the rear wheels and use the 18mm socket to loosen the sway bar nuts as shown
Now, remove the shock bolts using the 21mm socket
Once the sway bar connections and shocks are disconnected, very slowly drop the rear end down, careful not to snag any sensor wires or brake lines.
As the rear end comes down, the springs will loosen and free up. Go ahead and pull the springs out. It might take a little bit of gentle persuasion.
Gapp is offline   Reply With Quote
Old 09-24-2006, 12:09 AM   #2
Gapp
Default
Notice the difference between the stock and the new Eibachs:
Take the rubber off of the stock springs and put on the new ones. The rubber prevents any noise from the spring coils touching.
Reinstall everything in reverse. Have a buddy jack the rear up as you guide the springs back into position. Re-tighten everything up and that's it for the rear.
Now the fun part! The front!
Use the e-brake to keep the back from moving and use the engine crossmember as a jacking point. Position the stands like before on the frame rails and remove the front wheels. The front uses coil over shocks and provides a pretty supple ride.
Old 09-24-2006, 12:10 AM   #3
Gapp
Default
Start by removing the two 15mm bolts on each side that hold the bottom of the coil over assembly to the lower control arm.
Now, locate and remove the 3- 18mm nuts on each coil over holding it from the top. You can do it from underneath or on top. (I did both) The top will require the use of some extensions to reach.
Old 09-24-2006, 12:11 AM   #4
Gapp
Default
Now once all the nuts/bolts are removed, use the pry bar to remove the assembly from the bottom.
Here's the assembly next to another important tool...
Now, loosen the 18mm nut on each top hat of the coil over SLIGHTLY. Do not take it off, you will be SERIOUSLY INJURED by the spring. Use the spring compressor to take the tension off the spring. Once the tension is off, remove the 18mm nut and pull the top hat and spring off the shock.
You need to replace the stock bump stop with the supplied bump stop or cut 2" off of the stock one. This will allow for use of the stock shock and make for a factory ride.
Old 09-24-2006, 12:12 AM   #5
Gapp
Default
Be sure to do one side at a time to allow a stock reference to the order of the dust boot, spring top and bottom, bump stop, etc. Reinstall everything in reverse and tighten up all nuts and bolts. Drop the truck down and admire your new stance!!
Here's the before and after. Not a huge difference, but better! Happy slammin!!
DISCLAIMER: This is how I did it, and I am not responsible for any damage, injury, or negligence as a result of your installation. Use common sense and be safe!!!
Old 09-25-2006, 08:43 PM   #6
basecorvette
Tahoeforum Noob
basecorvette is on a distinguished road
Default Nice!!
Great write up and step by step pics. Thanks. Tahoe looks awesome.
basecorvette is offline   Reply With Quote
Old 11-26-2006, 07:24 PM   #7
tbourg4
Tahoeforum Noob
tbourg4 is on a distinguished road
Default
How does it ride compared to factory? What size tires do you have and the offset of the wheels, and does it rub any?
tbourg4 is offline   Reply With Quote
Old 11-29-2006, 01:13 PM   #8
Gapp
Default
It rides nice and handles great. There is less suspension travel so it doesn't feel like you are floating on a cloud anymore. As with any lowered vehicle, you trade off a little comfort for performance. To each his own!
As for the size, they are 275 55 r20's and IIRC, the offset is +40. I have had no rubbing issues whatsoever.
Old 12-19-2006, 01:42 AM   #9
meathead
Tahoeforum Noob
meathead is on a distinguished road
Default lift, not drop
Nice write up. Pretty straight forward. However, I'm looking for about a 2-3" lift. Any suggestions w\out messing up the ride or gas mileage?
meathead is offline   Reply With Quote
Old 03-25-2007, 10:18 PM   #10
SlickTahoe
Tahoeforum Noob
SlickTahoe is on a distinguished road
Default Eibach w/ autoride
I installed a set of Eibach springs on my 07 w/ autoride this weekend. The front dropped 2-3/4" and the rear 2-1/2". The install went very well. Eibach includes shorter push rods for the autoride sensors. The ride is great but the front is so low I can't roll a floor jack under. The truck still has the stock looking rake. I was looking for a level look as well. I ordered 2" spacers for the front to level the truck. I hope I can cut them down to 1-1/2". I think this will give the truck a good "SS" look.
SlickTahoe is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
