Go Back   Tahoe Forum - Chevy Tahoe Forum > 2007 + Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > Technical Discussions
Register to remove these ads.
Reply
Thread Tools Display Modes
Old 08-24-2008, 10:34 PM   #1
dragnfli
Tahoeforum Noob
dragnfli is on a distinguished road
transmission kicking into neutral
I have a 2005 Z71 Tahoe. Sometimes it will kick out of gear while driving down the road. So I pull over and you can hear a light grinding noise from the transmission. Go to put it in Park and it grinds while going through reverse (only took one time for me to not do this again). The way to get it going again is to put it in neutral put it in 4WD then back to 2WD and all is fine. This only seems to happen sometimes when going around left hand corners. I let off the gas to go around the corner and when I go to get back on the gas it has kicked out of gear. Thanks in advance for the help.
dragnfli is offline   Reply With Quote
Old 08-26-2008, 02:39 AM   #2
JD Larue
JD Larue's Avatar
JD Larue is on a distinguished road
Default
No idea bro. Time to take it to a tranny shop or dealership. What your describing is not a good thing.
JD Larue is offline   Reply With Quote
Old 08-26-2008, 02:53 AM   #3
Black Dog
Black Dog's Avatar
Black Dog is on a distinguished road
Default
I think it sounds like the shift linkage needs adjustment, with possible replacement of those bushings, because I think with the engine torquing and body flexing around a corner it could be popping out of gear. On the other hand, grinding sounds like it could be the transfer case, and also since you are adjusting the transfer case gears to correct it. So still linkage, but maybe for the transfer case instead of the trans. Remember the transfer case has a neutral position too, and isn't it a manual shifter on that year truck? Or you might be surprised to find out that there's a bad trans or motor mount, when the drivetrain moves and the linkage doesn't, it could shift.
Black Dog is offline   Reply With Quote
Old 08-26-2008, 08:42 PM   #4
johnebgoode
johnebgoode's Avatar
johnebgoode is on a distinguished road
Default
Definately an internal problem. Have a qualified shop diagnose it for you.
johnebgoode is offline   Reply With Quote
Old 08-27-2008, 10:26 PM   #5
KarenCaren
Tahoeforum Apprentice Member
KarenCaren is on a distinguished road
Default
I have read some Q/A website about that problem. So many answers but only one thing is really the solution. They gone to the dealer and let the dealer check their transmission.
_________________
Must Read: Autopartswarehouse.com
KarenCaren is offline   Reply With Quote
Old 08-31-2008, 07:20 PM   #6
Black Dog
Black Dog's Avatar
Default
Like I said, if it's only popping out of gear during a corner while going off then on the gas, it is most likely flexing its way out of gear. Parts move away from other parts, the linkage is connected to both body and gearbox, making the linkage move unwanted and if its worn or not adjusted it could pop position. Whether it's tranny or transfer case remains to be seen, but this is the first place I'd check on both.
Old 08-31-2008, 07:22 PM   #7
Black Dog
Black Dog's Avatar
Default
And if the transfer case is grinding make sure it has fluid, I had a 74 Suburban whos transfer case would not budge, only grinding, simply because it became dry.
Old 11-10-2012, 08:47 PM   #8
theclimberjoe
Tahoeforum Newcomer
theclimberjoe is on a distinguished road
Default Solution??
Hey dragnfly
I was wondering if you ever came up with a solution, I am having the same problem on my 04 tahoe. The auto4x4 works fine, but if I put it into 2wd it will slip out of gear, read your post and was wondering if you ever came up with a solution.
theclimberjoe is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
