Register to remove these ads.
Reply
Thread Tools Display Modes
Old 08-24-2008, 09:38 PM   #1
dragnfli
Tahoeforum Noob
dragnfli is on a distinguished road
2005 Z71 will not start
Sometimes when I go to start my tahoe nothing happens. Lights and all work fine. If I continue to let off the switch and keep trying it will finally kick over and start just fine. Sometimes is may only take 10 or so tries other times over 50 to get it started so I can get back home. Could it be a bad spot on the starter? How can I test to isolate the problem? thanks in advance.
dragnfli is offline   Reply With Quote
Old 08-27-2008, 09:32 PM   #2
KarenCaren
Tahoeforum Apprentice Member
KarenCaren is on a distinguished road
Default
Hello. If you are experiencing this problem you might have a dead battery. A quick test for the state of a battery charge is to turn the ignition key to the on position, and turn on the wipers. If the wipers move real slow or not at all the battery needs to be charged. A jump start will get the vehicle started. If you allow it to run a couple of hours the battery will recharge if it is a good battery. A battery 4 or more years old will need to be replaced. Also check the battery cable and connections. If they are loose or corroded they will contribute to the no start. Another cause of a no start is lack of fuel to the engine. In this case the engine will crank over and sound as if it wants to start. A quick test is to turn off all accessories, turn the key to on and listen for a low volume humming noise. This noise is the fuel pump. If there is no noise it is likely the engine is not getting fuel. A blown fuse, faulty relay, or bad fuel pump may be the cause.
____________________
Must Read: Autopartswarehouse.com
KarenCaren is offline   Reply With Quote
Old 08-28-2008, 02:11 AM   #3
tnezukon
tnezukon's Avatar
tnezukon is on a distinguished road
Default
I would say start by checking all the connections to the battery. If the lights are working and they arent dim when you turn them on I wouldnt think that its a bad battery. Does the engine turn over, or do you just hear a "click". If its the latter I would def say its either a loose connection or perhaps a bad starter solenoid. Hope this helps
tnezukon is offline   Reply With Quote
Old 08-29-2008, 11:45 AM   #4
dragnfli
Tahoeforum Noob
Default
Thanks for your replies. The battery new and I know it has nothing to do with battery connections. All the electical works fine with no problems. When I turn the key to start, then basically nothing happens. Engine does not turn over, solenoid does not click on the start either. Next thing I am going to try is see if fire is getting to the starter or not when I turn the key. I am thinking bad solenoid on the starter, but not sure how to isolate down on this vehicle.
Old 08-29-2008, 12:28 PM   #5
bunkleman21
bunkleman21 is on a distinguished road
Default
I had the same problem in March. I would just keep trying for sometimes a half hour to get the damn thing to start. All of the acc. would turn on but the truck wouldnt turn over, or do anything. If you go under there and tap the starter with a hammer it should spin it if there is a dead spot and it should start. If that works you need a new starter. cost me $200 at Autozone, and I havent had a problem since (knock on wood). Also if you take it out and take it into Autozone they will test it for free for you. BTW, it is a pain in the a$$ to get to under there.
bunkleman21 is offline   Reply With Quote
Old 08-29-2008, 12:37 PM   #6
dragnfli
Tahoeforum Noob
Default
Sounds like that is my problem. It is dead right now in the yard, will go home tongiht and try it. Thanks for the reply.
Old 08-29-2008, 01:07 PM   #7
bunkleman21
Default
no problem, hope it works for ya
Old 09-03-2008, 10:19 AM   #8
dragnfli
Tahoeforum Noob
Default
Just so everyone knows it was the starter solenoid. Took the starter off $170.00 for a reconditioned one at the parts store. Thought that was way to much so I took it to my local alternator and Starter repair shop. $35.00 to replace and put the solenoid on and another $15.00 to open up the starter, lube it up and check the brushes. GOOD as new!
Thanks for everyones help.
Old 09-03-2008, 10:47 AM   #9
bunkleman21
Default
Thats a good deal. I wish I would have done that. Glad to see it worked out. Did you do the install. I ask because when I did it I forgot to put the plastic housing back on until I was rolling the crawler out and saw it laying there:cuss:. I had to do the whole install process a total of 3 times. The first time I forgot the heat shield, the second time the gound was touching the block and completing the circuit all of the time and the starter wouldnt turn off, the third time it worked. It was a simple job that got me significantly frustrated
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
