Go Back   Tahoe Forum - Chevy Tahoe Forum > 2007 + Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > General Tahoe/Yukon/Escalade Discussion Forum
Welcome to the Tahoe Forum - Chevy Tahoe Forum.
Register to remove these ads.
General Tahoe/Yukon/Escalade Discussion Forum General Discussion Forum
Reply
Thread Tools Display Modes
Old 10-06-2008, 01:50 PM   #1
0tommy0
Tahoeforum Noob
0tommy0 is on a distinguished road
Default 99 Yukon Denalli fuel problem?
Register to remove these ads. It's free!
Hello everyone, Very nice forum you have here.
I have a 1999 Yukon Denalli 5.7 4x4. over the weekend it started running bad like it is starving for fule when throtle is applied. It works fine at an idle.
I replaced the fuel filter and it did not help. I replaced the fuel pump about 2 years ago when it got really loud, I dont hear the pump this time, but could that be the problem? Oh I read the error codes and their is none that were not their before. The error codes i have had for a few months now are low voltage to thw cam position sensor (i replaced the sensor and it did not fix), and low voltage to the mass air sensor.
Any help would be greatly apreatiated.
0tommy0 is offline   Reply With Quote
Old 10-08-2008, 12:14 PM   #2
0tommy0
Tahoeforum Noob
I found this guy with the same exact problem...
99 GMC Yukon stuttering
My 99 Gmc Yukon SLT 4x4 4 door with 5.7L v8 Vortec and 4L60E auto tranny with electric 4wd selector, has a problem. It runs fine when you start it up and for the first few miles, then the engine will not go over 1200 RPM without missing and completely dying out. I took it to a mechanic and he/we found a bad O2 sensor that was replaced and it now has an entirely new exhaust from manifold to tailpipe including catalytic convertors. The timing was adjusted (as much as is possible)and all injectors are operating correctly. No trouble codes are set and if you turn it off for 30 secs or so and restart it, it will run fine for a few minutes then start doing it again. It seems to me that it would coincide with the PCM going to "closed loop" but my mechanic is telling me the duration of injectors being opened and closed does not change. I changed the fuel filter and have dead headed the fuel pump to find out the pump generates 90 psi when it has no outlet. When I check pressure at the fuel line test port I only get 50 psi. Is it possible the fuel pressure regulator is bad? The fuel pressure does not change when it is running correctly or poorly. Any ideas or thoughts? I have checked and traced all grounds and have repaired a couple of connections(cleaned and recrimped new wire ends to ensure solid good contact), I have even gone so far as to verify the connections with an ohmmeter. What is the pressure supposed to be on the fuel rail? I have heard and found anywhere from 60 to 75 psi.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
