Register to remove these ads.
Reply
Thread Tools Display Modes
Old 10-08-2008, 11:15 PM   #1
hart
Tahoeforum Noob
hart is on a distinguished road
Default 99 tahoe misfiring
Any help will do!
My 99 tahoe has been misfiring on cyl.5 for some time now, I have changed cap and rotor, wires, plugs, and a cylinder pressure test. Then it would not start. Took it to the dealer and they changed the injector. It starts fine now and still has a misfire and the mechanics were puzzled, and did a injector balance test and turned out fine.
I am moving across the country in a month and would love to solve this issue.
P.S. Anyone in Cali with a misfire there is a warranty recall pushed by the state of Cali, since they are a big emisison state. I can give more details if anyone needs it.
hart is offline   Reply With Quote
Old 10-09-2008, 01:30 PM   #2
[email protected]
Tahoeforum Apprentice Member
tim@sp is on a distinguished road
Default
Take out the plug after running it... Is the plug wet or dry? If it is wet then you are not getting any spark, if its dry then you are not getting any fuel.
Check the harness on the top of the upper intake plenum. Put some contact cleaner and dialectric grease on the pins... that took care of my #7 misfire.
tim@sp is offline   Reply With Quote
Old 10-09-2008, 09:28 PM   #3
hart
Tahoeforum Noob
Default
I put my timing light on #5 and I have spark the plug is wet, I will check the connection thanks
Old 10-10-2008, 12:02 PM   #4
[email protected]
Default
Sounds like its in the Distributor. I remember hearing about the distriutor gear getting to wore and causing a misfire...
You know now its not fuel... its spark, so concentrate your efforts there.
I will do some more digging and see what I can find...
Old 10-10-2008, 04:17 PM   #5
hart
Tahoeforum Noob
Default
I was starting to think that today as well. I am going to dig some more this weekend, I like to hear someone also came up with the same idea.
Old 10-25-2008, 02:41 PM   #6
rsashea
Tahoeforum Noob
rsashea is on a distinguished road
Default Tite Valve Guides
I chased a missfire for about a year that would occur under a load, most of the time on accel onto a parkway. Turned out to be tight valve guides causing the exhaust valves on certain cylinders to hang open momentarrilly and then return to normal. The check for this was to remove the valve cover, rocker arm and valve spring on the suspect cylinder.(Do this with the piston at the top of the stroke to keep from loosing valve into cylinder) Pull up on valve stem to seat valve and rotate. If valve seems to be sticking this is a good indication this is the problem. There are two options to correct. GM says to open up guide clearance an additional .002 however I opted to just replace the heads with a good set of new aftermarkt units. Just some food for thought, hope it helps. Ron
rsashea is offline   Reply With Quote
Old 10-25-2008, 03:02 PM   #7
treepete
treepete's Avatar
treepete is on a distinguished road
Default
Hi Ron, welcome to the forum.
What type of heads did you use as the replacements.. just curious.
treepete is offline   Reply With Quote
Old 10-26-2008, 01:59 AM   #8
Blue96Tahoe
Tahoeforum Newcomer
Blue96Tahoe is on a distinguished road
Default
it could be a tight valve also. I adjusted one of mine too tight on mine and it caused a miss. If it has done it for a long time you could have burnt the valve
Blue96Tahoe is offline   Reply With Quote
Old 10-26-2008, 07:55 PM   #9
rsashea
Tahoeforum Noob
Default Thanks for the welcome.
I got the heads from a friend who owns a machine shop. They were just some generic aftermarket assembly's. Ron
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
