Go Back   Tahoe Forum - Chevy Tahoe Forum > 2000 - 2006 Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > Audio, Video and Alarm Discussions
Register to remove these ads.
Audio, Video and Alarm Discussions This forum is for discussing audio and video topics. Such as upgrading or repairing your A/V system.
Reply
Thread Tools Display Modes
Old 11-23-2008, 09:05 AM   #1
Jake007
Tahoeforum Noob
Jake007 is on a distinguished road
Default 2002 Factory Amp
I have an 2002 with no Bose and no OnStar. Just upgraded my sterio to a nice Alpine and 4 Alpine speakers with amazing improvement (old speaker cones were ripped). However, the Alpine does power a factory amp which powers the speakers and a rear sub in the rear storage area.
1. Does anyone know what the power output specs are for the factory amp that is located behind the glove box (including the sub power output)?
I am trying to decide if the Alpine output would be better or the amp output.
2. Also, anyone know how to get the glove box out to access the amp?
Jake007 is offline   Reply With Quote
Old 11-27-2008, 12:01 PM   #2
Jake007
Tahoeforum Noob
Default
Anyone......
Old 11-27-2008, 12:42 PM   #3
Sepiroth
Spam Executioner
Sepiroth's Avatar
Sepiroth is on a distinguished road
Default
I do not know the output of the factory amp, nor do i know the specs of the subwoofer. IMHO, the stock stuff is just that, stock stuff. The amp and sub are IMO cheap and any aftermarket replacement is sure to sound much better.
I say replace the stock sub and amp. You can house the new amp in the space with the amp, I believe, and you're in business
Sepiroth is offline   Reply With Quote
Old 11-27-2008, 01:13 PM   #4
oneradride
oneradride's Avatar
oneradride is on a distinguished road
Default
Just want to make sure I understand that question…
The RCA leads coming from the Alpine are line level outputs; you cannot hook a sub to them directly. Well I suppose you could but it would be pointless.
In order to run the factory sub or amp you are going to have to interface the aftermarket head unit into the factory amp to give it some kind of signal and trigger. This, IMO, is not the best approach… One because the factory amp sucks. Two because I don’t know how to do it. (don’t really care either, because of one )
oneradride is offline   Reply With Quote
Old 11-27-2008, 10:16 PM   #5
Jake007
Tahoeforum Noob
Default
Clarification..... My current hookup has a new Alpine head unit connected by speaker wire output of the head unit to the factory amp (not via RCA outputs). So basically I think I am currently only seeing the benefit of the factory amp to the speakers. I was trying to find out if I would be better off to cut out the factory amp and leave the rear damaged sub disconnected therefore only using the Alpine built in amp vs the factory amp? (Alpine HU wired directly to speakers or Alpine HU to factory amp to speakers??)
Old 11-27-2008, 11:06 PM   #6
oneradride
oneradride's Avatar
Default
Cool got yah, but I’m not sure how you did that… most amps take a line level signal (because it’s a cleaner source) and then jack the power to it. If you are running speaker level signal into the amp I’ll bet that sub sounds like ****…..
You said earlier that this is not a bose system… Unless I’m mistaken the factory amp only powers the sub. The head unit powers everything else.
Your best bet would be to use the head unit power to the factory speakers. Replace the sub with a nice 8 inch that’ll fit in the same box and look up a small 100 watt amp right next to or in the same area as a factory sub, there is ample room under that panel. This will also require a heavy gauge wire, trigger lead and RCA run all the way to the back.
Old 11-27-2008, 11:55 PM   #7
Jake007
Tahoeforum Noob
Default
Thanks for the reply. I initially hooked up my new HU and had no sound. That is when I realized there was a factory amp. So I connected up the blue line and now all speakers worked. So I think in this year the amp must power all speakers.
So it seems that I should find the factory amp, throw it away, bypass all speaker connections accross the factory amp, and install a new sub amp dedicated to a new sub. Then my new Alpine HU with new Alpine speakers and new XX brand sub will sound great... without breaking the bank....
Old 05-10-2016, 06:19 PM   #8
boogadee
Tahoeforum Newcomer
boogadee is on a distinguished road
Default
the stock amps usually put out 20 amps per chanell.
if u open glove box on right side is a plastic tab. just pry it to the left and it drops down
boogadee is offline   Reply With Quote
Old 05-10-2016, 06:22 PM   #9
boogadee
Tahoeforum Newcomer
Default
sorry just realized this was old
Old 08-21-2016, 07:55 AM   #10
Srad600
Tahoeforum Newcomer
Srad600 is on a distinguished road
Default
Sorry to bump an old thread but I cant find an answer to my question. Believe it or not I used to install car audio for a living but that was more about 15 years ago and I just dont remember a lot of the stuff.
I have a 2002 just like this one, no bose, no onstar, WITH factory amp and sub. I dont have the small harness with pink wire every one says to hook up to the radios amp turn on wire. I tested in the cars harness and found a green wire that acts like amp turn on so I powered it up and I have sound! but only when the car is stationary!?!?! If I move at all the amp cuts out.
Some one have an answer for me thats quick and cheap before my road trip this week?
Srad600 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
