Register to remove these ads.
Reply
Thread Tools Display Modes
Old 11-27-2008, 01:21 AM   #1
kev-de
Tahoeforum Noob
kev-de is on a distinguished road
Default multiple/random misfire code P0300
I have recently baught a non running engine and rebuilt the engine. At start up it ran rough and threw a code of P0300 random/multiple misfire. It has a new cap, rotor, wires, and plugs. Has any one else had any simular issues? Could it be some other sensor? I plan on testing the cam, crank and knock sensors. I have replaced the fuel pump, fuel injectors and all the internal parts of the engine. Not sure where to start. I also had to replace the ignition key, key was lost. Thanks
kev-de is offline   Reply With Quote
Old 11-27-2008, 08:27 AM   #2
treepete
treepete's Avatar
treepete is on a distinguished road
Default
sounds like the distributor is off a tooth or two, but it could be other things as well.
others will be in to help Im sure.
welcome to the forum,
Pete
treepete is offline   Reply With Quote
Old 11-28-2008, 07:58 AM   #3
mygreen98
mygreen98 is on a distinguished road
Default
distributor replacement i critical. i'd go there first.
mygreen98 is offline   Reply With Quote
Old 12-02-2008, 03:53 PM   #4
kev-de
Tahoeforum Noob
Default
Thanks for the info, I moved the distributor both way a tooth and it was worse. Do you think it could be the crank or cam sensors? Why would you replace the whole distributor? Any help would be great. thanks
Old 12-02-2008, 04:03 PM   #5
treepete
treepete's Avatar
Default
hmmm...
everything go OK with the engine rebuild? tell us more of what you did and stuff and we'll keep looking to help you.
did you get new rings, pistons and everthing in the engine? heads still stock? same cam etc?
Old 12-02-2008, 04:33 PM   #6
mygreen98
Default
i meant resettting of dist. proper resetting of timing must be done with a scan tool.
Old 12-02-2008, 04:34 PM   #7
mygreen98
Default
the internals of the distributor are actually the cam sensor itself, thus resetting reqires a scan tool.
Old 12-02-2008, 05:11 PM   #8
kev-de
Tahoeforum Noob
Default
A little history on the engine. The guy I bought it from ran it low on oil and kept driving it. on the tear down all the main bearings were spun as well as the cam bearings. sent the block to the machine shop and had it bored 30 over, had to buy a scat crank, the old one was to far gone. Had the crank balanced. All the internals are new with the exception of the cam and lifters which had 10,000 miles bought on e-bay. The cam was also too far gone. There was no cam sensor in the distributor and replaced it with one that the guy I bought it from said it came from a running engine. It has new spider injuctors, new cap, rotor, and wires. Set engine at top dead center and lined up the distributor with the number 8 on the housing. The onlything else I replaced was the ignition switch because of a lost key. I get a code o P0300 and once in a while I get P1345. I am thinking about taking it to the shop and have a diagnostic run on it. please help, thanks
Old 12-03-2008, 06:30 AM   #9
Slammed
Slammed's Avatar
Slammed is on a distinguished road
Default
Do you get the codes in idle or while driving?
Slammed is offline   Reply With Quote
Old 12-04-2008, 04:43 AM   #10
kev-de
Tahoeforum Noob
Default
I got the P0300 at idle and the P1345 while driving. It barely stays running. It seems to smooth out a little bit at higher RPMs. One thing I forgot to add is I did not get the heads reworked and after start up I notice the exhaust was sucking back in at the tale pipe, must be a stuck valve or two.
Reply
Bookmarks
Tags
miss fires
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
