Quote:
Originally Posted by MarkR
I have a rattling in the front end and from the looks of it I need new lower ball joints. How hard are they to replace and wht kind should I get.
99 2dr 4X4
Thanks'
Mark
i got life time from napa,,,seem to be holding up good. hard to tell if they are bad by looking unless they are broken bad. jack that wheel up off the ground, grab the tire top and bottom and see if you can move it much. if it does move try looking inside and see if you can see the ball joint move when you do this. may as well grab the sides and see if it has a lot of movement also. look at tierod ends and pitman arm. usually the bad part will do the moving. it will move a little side to side when good but not much. all these parts go bad sooner or later
