Register to remove these ads.
Reply
Thread Tools Display Modes
Old 12-27-2008, 10:48 PM   #1
vermbird
Tahoeforum Newcomer
vermbird is on a distinguished road
Default spark plug changing
im new to this forum . does anyone know a good way to get out the #8 (passenger rear) spark plug? have tried 5/8" FLEX SOCKET, straight 5/8" socket, underneath car (no good). that cylinder has 110,000 miles on it and needs the plug changed. all the others i have replaced and put in new plug wires. thanks. vermbird.
vermbird is offline   Reply With Quote
Old 12-27-2008, 10:53 PM   #2
jordankreutzer
Tahoeforum Apprentice Member
jordankreutzer's Avatar
jordankreutzer is on a distinguished road
Default
not sure about getting it out, but once you do and you go to install the new one, a short piece of rubber hose that fits over the end of the spark plug will make installing it that much easier.
jordankreutzer is offline   Reply With Quote
Old 12-28-2008, 03:31 AM   #3
Tahoe7689
Tahoe7689's Avatar
Tahoe7689 is on a distinguished road
Default
I got under the truck and put the regular socket on around the spark plug first, then popped the socket wrench on the socket then took it out. I also put the new one in from under the truck
Tahoe7689 is offline   Reply With Quote
Old 12-28-2008, 02:49 PM   #4
boostaholic is on a distinguished road
Default
Did you get the heatshield off? I had to get under the last denali I changed plugs on to pop the shield with a flathead, then I used an angle socket and it came off easily. Driver's side is usually more difficult, don't forget to use some anti-seize and gap those bishes to .040.
boostaholic is offline   Reply With Quote
Old 12-28-2008, 05:00 PM   #5
Tahoe7689
Tahoe7689's Avatar
Default
no, i didnt need to get the heat shield off, but i did struggle for a few minutes then I got the socket around the plug and it came right out.
Old 01-22-2009, 07:51 PM   #6
Big Blue Tahoe beast
Tahoeforum Noob
Big Blue Tahoe beast's Avatar
Big Blue Tahoe beast is on a distinguished road
Default
I also want to know as I just got back from the auto shop and they said they want to charge me $214 to exchange out the spark plug???? Um no I will not pay that price.
They also said that I need to get a new water pump and they want to charge $500 for it when I have found them online from $90-$180 so I think we are gonna see about doing ourselves or hire a mechanic on the side to do it.
Also my engine light came on 2 days ago and it has a code of I believe 09 and they said it's one of two things either a intake or a exhaust ring??? And it might run from $300-$500.
Holy cow!!!!
Big Blue Tahoe beast is offline   Reply With Quote
Old 01-23-2009, 12:08 AM   #7
Tahoe7689
Tahoe7689's Avatar
Default
do the plugs yourself, its easy all you need is a wrench (and a shop manual might help give you some direction, chilton is a good one that is sold at most auto part shops)
I have had my water pump replaced and it did cost me $500 through the stealership. I would recommend getting an OEM pump through ebay or a part store that sells basically new parts like G&R auto parts their number is 405-634-0575 (they ship). They have lots of parts and I have used them to replace some parts on my car, its usually half what the dealer wants for (just the part) and I have never had any trouble with their parts (air condt. pump and a MAF sensor along with many cosmetic parts). The shop manual will tell you how to replace the pump it shouldn't be too bad, but it might take a while. If you want to save a lot of money do it yourself, and besides then you will have the satisfaction of saying you did it yourself!! haha! But if you dont want to do it yourself buy the pump yourself and have the stealership replace it for you it would still be way cheaper. (you also might want to check and see if you really need to replace the pump, what did they say the reason was? usually they are replaced if they are leaking).
Have somewhere like autozone check the engine code, its free. They will tell you what it means (if not then use the chilton manual, it has a code library in the back). Then decide if you can fix it yourself.
Old 08-10-2017, 02:59 PM   #8
blk2012gt
Tahoeforum Newcomer
blk2012gt is on a distinguished road
Default
Quote:
I got mine out just 2 weeks ago. Flex and wobble sockets didn't work. I came in through the top, placed my plug socket on first with a very small extension attached. Once I did that, I attached the wrench and came off pretty easy after that. The small extension was the key for me.
Sent from my SM-N920P using Tapatalk
blk2012gt is offline   Reply With Quote
Old 08-20-2017, 03:01 PM   #9
chubbs
chubbs's Avatar
chubbs is on a distinguished road
Default
I replaced the plugs in my truck last night with little difficulty, although a specific setup is called for. different people handle it different ways. I had more trouble removing the lead/boot than the actual plug itself.
see image attached.
1/2" drive ratchet
1/2" to 3/8" drive adapter
3/8" drive spark plug socket 5/8
that little adapter for the 3/8 spark plug socket gives you just enough length to both capture the spark plug and clear the manifold, then the 1/2" ratchet provides the leverage required. use your free hand to maintain the central axis of rotation so that you are torqueing in a circular motion instead of pushing/pulling. spark plugs this old should be handled with some caution in mind. I'm always paranoid it will strip out and ruin my life.
chubbs is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
