Register to remove these ads.
Reply
Thread Tools Display Modes
Old 01-05-2009, 04:32 PM   #1
gutsco37
Tahoeforum Noob
gutsco37 is on a distinguished road
Default HELP! 99 Tahoe Shuts Off Electrical Problem
I'll be driving down the road and the vehicle shuts off or stutters and almost shuts off. I also lose all electrical power in the vehicle while this is occuring. Its almost like somebody is shuttting a light switch on and off.
If the vehicle stalls, I am able to restart the car the issue goes away, and eventually comes back randomly...
I've checked the terminals and they look good... I've read that these vehicles are prone to bad ignition switches... Could this be the problem? Or is there some kind of relay I should be looking for?
gutsco37 is offline   Reply With Quote
Old 01-05-2009, 09:26 PM   #2
73shark
73shark's Avatar
73shark is on a distinguished road
Default
Welcome to the Tahoe Forum. Might get more answers in the section for older Tahoes.
73shark is offline   Reply With Quote
Old 01-06-2009, 07:10 PM   #3
MikeyG79
Tahoeforum Noob
MikeyG79 is on a distinguished road
Default
had the exact same thing happen to my '99 and all it was were loose battery cables.
MikeyG79 is offline   Reply With Quote
Old 01-06-2009, 08:39 PM   #4
TahoeGoBoom
TahoeGoBoom's Avatar
TahoeGoBoom is on a distinguished road
Default
i had it happen in another car, not my tahoe, but it ended up being that the ground to the car itself (not the battery ground, the chassis ground) was bad. mine eventually quit starting until i had the ground completely replaced.
TahoeGoBoom is offline   Reply With Quote
Old 01-08-2009, 06:06 PM   #5
gutsco37
Tahoeforum Noob
Default
A closer inspection today revealed that a ground wire is totally rotted off! The ground is in the lower left hand side of the firewall/engine compartment area. It is a braided wire. It actually looks like there is 2 of them. What exactly do these ground? Could this be my problem?
Old 01-09-2009, 10:14 PM   #6
73shark
73shark's Avatar
Default
Usually this type of ground strap is to ensure that all of the metal in the vehicle is at the same ground level. That way lites, ECM, etc just need to grounded to the body and don't have to have a ground wire all the way to the battery. Bad grounds are a tough nut to crack as can cause some strange problems like your dome lite comes on when you hit the brakes.
Old 02-25-2009, 09:16 PM   #7
gutsco37
Tahoeforum Noob
Default
Unfortunately replacing this faulty ground did not fix my problem? Any ideas what to try next? It shut off again yesterday (lost all power as it was shutting on and off)
Old 02-26-2009, 06:11 AM   #8
treepete
treepete's Avatar
treepete is on a distinguished road
Default
does the engine kill at the exact same time, or just after this occurs?
treepete is offline   Reply With Quote
Old 02-26-2009, 07:57 AM   #9
gutsco37
Tahoeforum Noob
Default
Its all happens at the same time. I would describe it as someone shutting a light switch on and off rapidly. Engine and ALL electric die and come back, die and come back. Sometimes it stalls the engine, and then I can pull over and restart. However when I restart after this occurs I would describe the shifting as clunky in the transmission like the ECM got messed up during the power cycles. After I shut off the vehicle for about 5 to 10 mins and restart it this corrects itself.
Old 02-26-2009, 08:52 AM   #10
DJTricky
DJTricky is on a distinguished road
Default
Quote:
this also happened to mine it was after hot import nights(thay have you disconnect the negative bat. cable) and i just put it back on and forgot to tighten it down
DJTricky is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
