Register to remove these ads.
Reply
Thread Tools Display Modes
Old 01-08-2009, 07:39 PM   #1
Jimweis
Tahoeforum Apprentice Member
Jimweis's Avatar
Jimweis is on a distinguished road
Default Differential Capacities
I just purchased a 2004 Tahoe w/ 65,000 miles. This weekend I want to change the differential oil in both ends to the $GM synthetic. This unit has an open rear differential since it is equiped with Stabilitrak. How much oil is required and is it true I'm to leave the fluid approx 1/2" below the fill plug hole in both diffs?
Thanks in advance,
Jim
Jimweis is offline   Reply With Quote
Old 01-09-2009, 07:41 AM   #2
Blizzardx23
Blizzardx23's Avatar
Blizzardx23 is on a distinguished road
Default
wish I could help...but I dont know =/
that new grape scent is fckin funny though hahha...have you smelled it yet? lol....
Blizzardx23 is offline   Reply With Quote
Old 01-09-2009, 08:09 AM   #3
667theneighbour
667theneighbour is on a distinguished road
Default
Have you checked the manual?
667theneighbour is offline   Reply With Quote
Old 01-09-2009, 12:14 PM   #4
Jimweis
Jimweis's Avatar
Default
Quote:
Owners manual has nothing on diffs
Old 01-09-2009, 09:12 PM   #5
boostaholic is on a distinguished road
Default
Fill level to the hole, I think the front takes 2qt rear 2.5 I'd buy 5qt your rear may take more since it's an open carrier. Hopefully the rear on your truck has a drain plug because gm started using AAM axles without a drain plug mid 2000's and it's a pain in the ass to change the fluid with the sway bar and crap in the way. I'd check your glovebox for the G80 RPO designation, most 8.6" 10 bolts in the suvs came with the limited slip (G80). Get a long rubber hose to allow easier fill, it's a bitch to fill the axles in these trucks esp the front. I changed my fluids to royal purple a few months back and the limited slip engages smoother as well as a bump in fuel economy. Make sure to use auto trak II blue fluid for the tcase, only use the gm fluid for these trucks in the transfercase.
boostaholic is offline   Reply With Quote
Old 01-09-2009, 10:21 PM   #6
Jimweis
Jimweis's Avatar
Default
Quote:
The owners manual states use Dextron-III for the Stabilitrak transfer cases and Auto Trak II for Auto Trak transfer cases.
I will check with the parts dep. I understand they can look up the correct fluid using the Serial #
Old 01-10-2009, 08:51 PM   #7
91RS
91RS is on a distinguished road
Default
The rear diffs take about 2.5 quarts so you'll need 3 bottles for that. The front diff takes about 1.75 quarts so you'll need 2 bottles for that. The parts department at the dealer will be able to look up the correct fluid for the transfer case by your VIN. An 04 Tahoe will not have a drain plug for the rear diff so if you're planning on doing this yourself you better go ahead and get a cover gasket for the rear diff to avoid any leaks.
91RS is offline   Reply With Quote
Old 01-10-2009, 09:48 PM   #8
Default
Don't buy a pre-formed gasket for the rear, use some permatex the right stuff
I've been using it for years and never have an issue, an air orbital sander makes quick work to remove the old gasket and clean the surface.
Old 01-11-2009, 07:17 AM   #9
Jimweis
Jimweis's Avatar
Default
So much for the dealer finding the fluids for my Stabilitrak TC the parts guy looked up the SN and said the TC requires manual trans oil
Old 01-11-2009, 08:18 AM   #10
91RS
Default
That's probably the case then. Here are the choices for GM transfer cases: ATF, Auto Trak II, GL-5, and Manual Trans Fluid. If the parts department looked up your VIN and they said you need manual trans fluid, then that's what you need. The GM manual trans fluid is red too so don't get confused. Oh, and the transfer case takes about 2.5 quarts if I remember correctly. While you're changing the fluid, you should also check your front diff and make sure the pinion seals and axle seals aren't leaking. They are pretty prone to it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
