Register to remove these ads.
Reply
Thread Tools Display Modes
Old 01-31-2009, 04:37 PM   #1
tybardy
tybardy's Avatar
tybardy is on a distinguished road
Default where to insert seafoam?
I bought two cans, put a full can into my gas tank and plan to run the other can through the vacuum lines and crank case... i am having a problem
I do not know which vacuum line to run the seafoam through... i have an 04 5.3, it does not have the standard large black break booster so i am not sure which vacuum line to disconect for the seafoam.
Anyone know?
tybardy is offline   Reply With Quote
Old 01-31-2009, 06:16 PM   #2
tybardy
tybardy's Avatar
Default
ok.... so i pulled the plastic cover off the motor, pulled the "upside down L" shaped hose off the passanger side of the intake manifold, sucked in a good half bottle of seafoam, turned the motor off. Let it stand 15 minutes, turned to motor back on and......
NO SMOKE! not even one single bit, NONE, ZIP, ZERO, ZILCH.... NADA
what did i do wrong?
Old 01-31-2009, 07:13 PM   #3
Grocery Getter
Grocery Getter's Avatar
Grocery Getter is on a distinguished road
Default
Did you pull the hose off the manifold side? You should have pulled the side off the block and sucked the sea foam into the intake manifold. I have an 04' as well and noticed that there was a sucking noise coming from the "L" connect on the block and no suction on the intake side so I thought it might go in there but then realized that it needs to go in the intake manifold so I shimmied my gas pedal down a bit and there was more than enough suction to suck it into the intake manifold..........and voila......smokey and the bandit
Grocery Getter is offline   Reply With Quote
Old 01-31-2009, 07:27 PM   #4
tybardy
tybardy's Avatar
Default
so let me get this strait... you disconnected the intake tube, opened up the throttle a bit and the just went right in that way?
I am worried that i just poured half a bottle of seafoam into the wrong place
Old 01-31-2009, 07:31 PM   #5
Grocery Getter
Default
I actually did suck a little into the block before I thought about it since it seemed to be the right place and nothing went wrong. So, yes..... the hose goes from the L shaped connector located on the block to the side of the intake manifold. You want to remove the end that is connected to the L shaped connector, have a buddy give some gas or shimmy the pedal down a bit, and suck the foam into the intake manifold. Sea foam can go into any part of the engine so I don't think it can hurt sucking it into the block but I am certainly not a mechanic............
Old 02-01-2009, 08:00 AM   #6
Grocery Getter
Default
Any luck?
Old 02-01-2009, 11:00 AM   #7
tybardy
tybardy's Avatar
Default
i have not given round two a shot yet,i will let you know in a few hours... if you dont hear from me... call the paramedics
Old 02-01-2009, 11:01 AM   #8
tybardy
tybardy's Avatar
Default
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
