Register to remove these ads.
Reply
Thread Tools Display Modes
Old 02-21-2009, 12:34 PM   #1
the99hoe
Tahoeforum Noob
the99hoe is on a distinguished road
Engine wont Turnover
Hey everyone,
The last time i posted it was about a stinking coolant leak. 99 hoe with the 5.7 and around 142K on the clock. i am the second owner and the original had fairly good documentation. I am back now because i found the leak; it was the dreaded intake gasket. So i have replaced the gaskets and i have the truck put back together now. The problem is the truck wont crank, everything powers up and i can hear the fuel pump cycle for about 3-4 seconds but when i push on over to the start position of the ignition switch nothing happens, no noise, crank wont turn nothing will happen. So what did i miss, i have checked all the harness connections and i was pretty thorough on disassembly to mark everthing. I have cleaned the battery connections and they look good and the battery is showing 12.1 volts on my voltmeter. Has anyone here had this problem, im needing some direction here any input is much appreciated.
the99hoe is offline   Reply With Quote
Old 02-21-2009, 01:22 PM   #2
the99hoe
Tahoeforum Noob
Default
Just a little more info i forgot earlier, the truck ran fine before this it was just leaking coolant.
Old 02-21-2009, 01:26 PM   #3
bsamoul
bsamoul's Avatar
bsamoul is on a distinguished road
Default
Have you checked your crank position sensor?
bsamoul is offline   Reply With Quote
Old 02-21-2009, 01:29 PM   #4
the99hoe
Tahoeforum Noob
Default
nope, i didnt touch it, only wiring that i messed with was on the top of the motor. But i will check it just in case, thanks
Old 02-21-2009, 07:40 PM   #5
qlc1964
qlc1964's Avatar
qlc1964 is on a distinguished road
Default
all the grounds reconnected and electrical connections
qlc1964 is offline   Reply With Quote
Old 02-21-2009, 08:27 PM   #6
the99hoe
Tahoeforum Noob
Default
Yup everything i disconnected i have reconnected, cleaned the battery terminals and rechecked everything. This has me really puzzled, i dont understand why it wont crank. I half way didnt expect it to run right or fire up because of the distributor being removed, but i marked it and got it back in the close to where it was when removed. I know i will have to have it timed and everything with the scan tool but i figured it would crank. Well for now im at a loss and i am probably going to check the starter silonoid next. Thanks for the ideas i appreciate it, i was hoping that someone may have ran into this, and i am now beginning to think i should have paid the money and let a pro do it, LOL. Guess this is what i get for trying to save money.
Old 02-21-2009, 08:54 PM   #7
79powerwagon
79powerwagon is on a distinguished road
Default
Try neutral... might be your NSS out of alignment or whack. Probably a battery cable issue, but the NSS can be to blame too...
79powerwagon is offline   Reply With Quote
Old 02-22-2009, 09:52 AM   #8
tahoe express
Tahoeforum Noob
tahoe express is on a distinguished road
Default
I would start by running a jumper cable on the ground side of the battery directly to the block bypassing the ground cable and seeing if it cranks.This is the easiest before tearing into it.The only other thing to do is back track by simply removing the distributor and leave it plugged in.See if it cranks.Hope this helps a little.
tahoe express is offline   Reply With Quote
Old 02-23-2009, 07:39 PM   #9
the99hoe
Tahoeforum Noob
Default
Well guys after days of no success and a shattered ego, I am shamefully having the Hoe towed to the mechanics tomorrow. I dont know what I did but this will probably change his slogan to WE FIX WHAT YOU F&^% Up. I appreciate the help guys and I will let you know what the culprit to this conundrum is, for now I sit in wonder, guess this means I'm not quitting my day job LOL. Thanks again for the help!!
Old 02-24-2009, 07:16 PM   #10
Beef
Tahoeforum Apprentice Member
Beef's Avatar
Beef is on a distinguished road
Default
Keep us posted, my 99 'hoe did the same thing but I dropped a new battery in and all was well. I would tried a diff battery if you didnt......
Beef is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
