Register to remove these ads.
Reply
Thread Tools Display Modes
Old 04-14-2007, 01:06 AM   #11
damassa
Tahoeforum Noob
damassa's Avatar
damassa is on a distinguished road
Default
i also have this same problem on my 98 tahoe and patiently await your posting :yesnod:
damassa is offline   Reply With Quote
Old 04-15-2007, 05:28 PM   #12
royd
Tahoeforum Noob
royd is on a distinguished road
Default steering slip 98 tahoe
For those of us who have been experiencing the steering slip, we seem to understand that it is due to an EVO or steering position sensor. Many of us think that it is the same thing. After talking to a GM technician, they are not the same thing. The EVO is located on the power steering pump in the engine compartment and the Steering Position Sensor is located on the steering column under the dash just above the brake pedal. After talking to the same technician, the problem is symptomatic of a faulty steering position sensor.
I will post a new thread sometime this week after I make the repair to let everyone know if the problem is corrected.
royd is offline   Reply With Quote
Old 04-15-2007, 09:04 PM   #13
jascbowman
Tahoeforum Noob
jascbowman is on a distinguished road
Default Steering slip
My mechanic replaced the steering position sensor on my 1999 Tahoe and this solved the steering slippage problem.(About $130.00 parts & labor)
jascbowman is offline   Reply With Quote
Old 05-09-2007, 06:42 PM   #14
Trip
Tahoeforum Apprentice Member
Trip's Avatar
Trip is on a distinguished road
Steering Problem solved by replacing the EVO
I just fixed my steering problem on my '99 Tahoe. Here is what you need to do. :thumbsup:
http://www.gmpartsdirect.com/
GM PART # 26064468
PACK QTY: 1
GM LIST: $64.75
OUR PRICE: $36.91
DESCRIPTION: SENSOR
thank
1. Remove the bolt and nut (15mm deep socket) that connects the bottom of the steering column to the intermediate shaft that passes through the firewall. (You may need to turn your wheel to lock to access the nut. Might be wise to make an alignment mark on the shaft)
2. Slide the intermediate shaft towards the firewall. It may feel fairly stiff but it will go.
3. Once the shaft is out of the way, pry out the 3 little plastic tabs that hold the sensor in place and slide the sensor out of the housing.
4. Unplug the wire harness on the old sensor and remove the sensor
5. Plug in the new sensor BEFORE you pop it into place. Trust me on this one!
6. Pop the new sensor into place with the wires at the top. One sidenote here: I found no reference marks, slots, or keys anywhere so I am not sure if it matters how it is aligned. The wires need to be on the top or they won't reach.
7. Reconnect the steering shaft.
Trip is offline   Reply With Quote
Old 05-10-2007, 06:16 PM   #15
mightymouse
mightymouse's Avatar
mightymouse is on a distinguished road
Default
GM PART # 26064468
PACK QTY: 1
GM LIST: $64.75
OUR PRICE: $36.91
DESCRIPTION: SENSOR
thank
Great post!:thumbsup:
mightymouse is offline   Reply With Quote
Old 05-14-2007, 04:28 PM   #16
kastiron
kastiron is on a distinguished road
Default
Quote:
I opted to go with the dealer install route as well. I was in for another service anyway, and they were a little kinder to me on the labor cost. $95 installed was the additional charge for me.
I spoke with the tech, he said it was a no-brainer and I could have handled it.
Thanks for this thread, I wish I had found it 140,000 miles ago.
kastiron is offline   Reply With Quote
Old 05-28-2007, 08:45 PM   #17
royd
Tahoeforum Noob
Default 98 tahoe steering slip
Just wanted to let everyone know that I replaced the steering position sensor almost a month ago in my 98 tahoe and the problem (steering slip) is gone! I mean not even any "minor play" in the steering. Cost for me was $105.00 for the sensor and 25-30 minutes to replace myself. If you decide to try the repair your self make sure the steering is locked in place and disconnect the battery. Best of luck!
Old 05-29-2007, 02:28 PM   #18
98tahoelt
Tahoeforum Noob
98tahoelt is on a distinguished road
98 Tahoe steering Problems
:thumbsup: I just changed my Steering Position Sensor and it fixed my steering slip problem. It did not take over 10 minutes to cure the problem. Simple install. I would do this ONCE per year if it meant that much of a differnece. WHAT A DIFFERNECE!!!
98tahoelt is offline   Reply With Quote
Old 02-08-2008, 10:22 AM   #19
Rick90467
Rick90467's Avatar
Rick90467 is on a distinguished road
Default
GM PART # 26064468
PACK QTY: 1
GM LIST: $64.75
OUR PRICE: $36.91
DESCRIPTION: SENSOR
thank
This is an older string, but it was very usefull to me. I stumbled upon it while searching for something else, and it pointed out a problem I had not even realized was there. I had always taken it to be the nature of the aged beast, litttle did I know. Thank you Tahoe Forum....:rom2:
Rick90467 is offline   Reply With Quote
Old 02-08-2008, 11:45 AM   #20
madspeed
madspeed is on a distinguished road
Default
same here!!! just replaced mine and BIG difference. Its a frickien wonder the guys at the alignments shops arent aware of this. Just had mine aligned last week and they said all was good, but it still wants to wander. stumbled upon this thread and BAM fixed!!
THANKS ALL!!
madspeed is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
