Register to remove these ads.
Reply
Thread Tools Display Modes
Old 10-02-2007, 11:27 AM   #1
boosted mahi
Tahoeforum Noob
boosted mahi is on a distinguished road
door adjustment?
Hey folks,
New owner here - 1997 4x4 with 80k on the clock. Bought it from the librarian of a small town - great previous owner! Anyhow, the drivers door sags a bit. As in, when you close the door it bangs a little and lifts up as it goes over the stud.
My old Range Rover allows me to adjust the door pitch by releasing, adjusting, and retightening some bolts.
Surely these doors are adjustable?????
Also, how many miles are the tie rods typically good for? I want to clean up the slop in the steering.
Thanks!
boosted mahi is offline   Reply With Quote
Old 10-02-2007, 11:46 AM   #2
JKmotorsports's Avatar
JKmotorsports is on a distinguished road
Default
GM ususally uses bushings that a hinge pins slides into. The bushings wear out and you have to replace the bushings and hinge pins.
To clean up the steering slop some, you can change the tie rod ends like you mentioned as well as replace the all the front end bushings.
JKmotorsports is offline   Reply With Quote
Old 10-02-2007, 12:18 PM   #3
boosted mahi
Tahoeforum Noob
Default
JK,
Thanks for the quick reply! I did examine the hinge pins last night and noticed the top hinge pin appeared offset to one side of its hole. Naturally this concerned me a bit, as I wondered if the pin had enlarged the hinge's holes!!! So, as I understand it, there are bushings that press into the holes and hug the pins?
And you are recommending that I replace the pins and bushings together, and not just the bushings? (Assuming the bushings are sold separately...)
Thanks again!
Old 10-02-2007, 12:36 PM   #4
Default
If the pin hasn't worn down considerably, then just bushings should be ok. But I'm not sure if they are available seperatley. I've bought a couple kits in the past for other vehicles and they had both pins and bushings.
Old 10-24-2007, 11:31 PM   #5
bigrick2179
Tahoeforum Noob
bigrick2179's Avatar
bigrick2179 is on a distinguished road
Default
ur steering problem can be as simple as a pittman arm mine was bad felt like i was driving a semi in a hurricane it was bad replaced it nows drives nicely
bigrick2179 is offline   Reply With Quote
Old 10-25-2007, 02:17 AM   #6
SmothZ71
Tahoeforum Noob
SmothZ71 is on a distinguished road
Default
Just had this fixed on my 97's driver door yesterday. Bushings/pins set at the dealership cost about $52. Or, you can buy all the parts individually.
SmothZ71 is offline   Reply With Quote
Old 10-25-2007, 03:35 PM   #7
Mike97
Mike97's Avatar
Mike97 is on a distinguished road
Default
Quote:
$52?:ack:
I've seen them for under $20 at my local Schucks.
Or try ebay
http://cgi.ebay.com/ebaymotors/95-00...QQcmdZViewItem
Mike97 is offline   Reply With Quote
Old 10-26-2007, 02:06 AM   #8
SmothZ71
Tahoeforum Noob
Default
Quote:
Originally Posted by Mike97 View Post
$52?:ack:
Or try ebay
Parts from a dealership will always cost a whole lot more than anywhere else. I'm a DIYer, I have always refused having a shop do work for me that I can do myself, or figure out so that I can learn something. Of course, this was an instance where I did not have the time available to do it myself, so I had to break my no shop rule :cryin:
Old 10-29-2007, 03:03 PM   #9
Hardwarz
Hardwarz is on a distinguished road
Default
So, does anyone have pics to go along with the pin/bushing replacement?
Also, my door spring popped out. I got the replacement parts, but haven't had time to do this.... Help?
Hardwarz
Hardwarz is offline   Reply With Quote
Old 10-31-2007, 05:52 PM   #10
ScottyG
Tahoeforum Noob
ScottyG is on a distinguished road
Default
make sure that you have a spring compressor. and a buddy to hold the door when you take off the hinges. you may be able to do one pin at a time but i found it easier with two guys, and floor jack with a 2x4 on it to hold the weight of the door.
ScottyG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
