Register to remove these ads.
Reply
Thread Tools Display Modes
Old 11-17-2007, 01:28 AM   #1
tahoeman21
tahoeman21 is on a distinguished road
Default Intake manifold leak
wassup? I am having coolant leaking from underneath the intake. I did some research and concluded that I have to change the gasket. My question is, what is the complexity of changing the intake manifold gasket? thanks
tahoeman for ever!!!:cool2:
tahoeman21 is offline   Reply With Quote
Old 11-17-2007, 01:43 AM   #2
LAP TOP GAMER
LAP TOP GAMER's Avatar
Location: flying somewhare in VATSIM&Delta virtual airlines
LAP TOP GAMER is on a distinguished road
Default
Are you talking air intake manifold?:skep:
LAP TOP GAMER is offline   Reply With Quote
Old 11-17-2007, 01:55 AM   #3
RonH
RonH is on a distinguished road
Default
You don't say what year or engine, so no specific answers for you. Whatever you have, you need to get some instructions, Chilton's or Haynes manual, or a service manual on DVD or something like that. The job is not rocket science, but there are some things that should be done in sequence and some pitfalls to avoid by knowning the proper procedures.
Good luck.
RonH is offline   Reply With Quote
Old 11-17-2007, 02:46 AM   #4
LAP TOP GAMER
Default
Fore example when reinstalling the manifold if you don't torque it in the proper sequence you will warp it.
Old 11-17-2007, 11:57 AM   #5
turbocamaro02
Tahoeforum Noob
turbocamaro02 is on a distinguished road
Default
Whats up tahoeman dude i'm having the same problem now with my 99 tahoe i knew it was leaking but soon as the cold weather hit it must of contracted and now its leaking like my ac drips its bad. i'm going to check mine out within a day or two let me know what you come up with. is your leak coming from the back of the motor?
turbocamaro02 is offline   Reply With Quote
Old 11-17-2007, 10:56 PM   #6
RonH
Default
Are you sure it's your manifold gasket? There's a coolant hose that connects to the manifold close to the throttle body on the passenger's side. Water seeping from this will drip from the engine and make you think it's coming from the gasket. Check it out before you tear into it.
Old 11-18-2007, 02:43 AM   #7
Mike97
Mike97's Avatar
Mike97 is on a distinguished road
Default
The 5.7 Vortec engine is notorious for the intake manifold leaking coolant. I had a 97 Chevy pickup with this engine, and it leaked coolant badly. At the suggestion of a mechanic friend of mine, I removed a few of the intake manifold bolts, coated them with RTV, and re-installed them. If I remember correctly, it was the front two on both sides. This worked for a while, but it started leaking again after about 6 months. So far, my 97 Tahoe hasn't had this problem (knock on wood).
Mike97 is offline   Reply With Quote
Old 11-18-2007, 03:11 AM   #8
LAP TOP GAMER
Default
I hope this isn't a problem with the 07 on up, well I guess that is why I have the 100,000 mile warranty.
Old 11-18-2007, 04:05 PM   #9
tahoeman21
Default
wassup guys? thanks for the replys.... btw, i have a 5.7 vortec, 2wd... it seems that it leaks from underneath the air intake manifold, the leak comes from the front of the motor. it leaks when it is park on my hill driveway.... the tahoe does not overheat though when i am driving it.... i am constantly adding coolant to the resouvier compartment,, but the radiator is full.... weird. i must fix this leak until it gets worse. I hope as well the new tahoes don't have this flaw as well, because i love them so much!
Old 11-19-2007, 10:54 AM   #10
CRXMotorsports
CRXMotorsports's Avatar
CRXMotorsports is on a distinguished road
Default
My understanding (non-GM-Technician here..) is that the intake manifold gaskets were each made of 2 materials, a plastic and a metallic. The issue was that they would either seperate, or not expand at the same rate, and it would leak typically as the engine was cold.. as the engine heated up, enough swelling occured to seal off this leak.
Again just my understanding of it as told to me by a few various yukon/tahoe owners... it is not the same block as the new ones.. this problem should be confined to 96-99s.. possibly it was even fixed in 98 or 99.
CRXMotorsports is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
