Register to remove these ads.
Reply
Thread Tools Display Modes
Old 11-27-2007, 01:46 PM   #1
Hardwarz
Hardwarz is on a distinguished road
Default Should I install a transmission cooler?
I'm hard on transmissions. The tahoe is the first light truck that I've owned in YEARS. I have a 99 Tahoe, 4 door 4x4 with the 350 Vortec. I actually baby the engine because of fuel prices.
I tow on occasions. Almost always under 1000 lbs and only once a month or less.
Do I have to worry about putting in a transmission cooler? Also, what's the best way to change the transmission fluid. I'm use to having drain plugs, this one, I don't want to drop the pan if I can help it.
Also, what transmission do I have? If I have to drop the pan, I'm just going to go to Summit Racing and pick up a pan with a drain plug and heat fins.
Hardwarz
Hardwarz is offline   Reply With Quote
Old 11-27-2007, 03:56 PM   #2
Mike97
Mike97's Avatar
Mike97 is on a distinguished road
Default
I installed a transmission cooler on my 97 Tahoe. I rarely tow anything, but I have had two transmissions die in other Chevy trucks I've owned. I figure better safe than sorry. Since the biggest killer of automatic transmissions is heat, it won't hurt to install a cooler. And it only took me a couple hours to do it.
If you want to change the transmission fluid, you will have to drop the pan. The filter is in the pan, and you need to change that when changing the fluid. But simply draining out what is in the pan only changes 20 to 30 percent of the fluid. Most of it is still in the transmission and torque converter. To completely change the fluid, you need to flush out the old fluid while adding new. This is best performed by a shop with the equipment to do it.
Your transmission is probably a 4L60E. If you are lucky it is a 4L80E, but I don't think they put those in any Tahoe's. This website describes Chevy transmissions and how to identify yours. http://www.nastyz28.com/chevy-transm...tification.php
Mike97 is offline   Reply With Quote
Old 11-27-2007, 04:02 PM   #3
Rollin Thunder's Avatar
Rollin Thunder is on a distinguished road
according to the link, that over drive was an the 4l80e and not on the 4l60e, so if you have over drive you most likely have the 4l80e but im not sure, i might have read the link wrong.
Rollin Thunder is offline   Reply With Quote
Old 11-27-2007, 04:23 PM   #4
Mike97
Mike97's Avatar
Default
No, the 4L60E is also an overdrive transmission. Basically an electronically controlled 700R4 with overdrive. The 4L80E is an electronic version of the TH400 with overdrive. Chevy pul the 4L60E in all their 1/2 ton trucks and some of their 3/4 ton trucks. The 4L80E was installed in 3/4 and 1 ton trucks.
Old 11-27-2007, 04:34 PM   #5
grin
i mis read the link th, i didn't think they put the 80 on half ton.
Old 11-28-2007, 10:23 AM   #6
Hardwarz
Default
Quote:
so, if the 4L60E is basically a electronically controlled 700R4, I can get a 700R4 pan for the Tahoe, correct? (Or are there several bolt patterns for pans I have to worry about?)
Hardwarz
Old 11-28-2007, 11:05 AM   #7
Hardwarz
Default
On my old Intrepid, I added a transmission cooler. I put it inline with the stock transmission cooler/heater. Did you do the same thing during your install?
Also, on the 'trepid, we usually disconnected the hose that goes to the cooler, start the car, and with the brake on, put it in drive. The pump would put out all the old transmission oil. Once that was done, we'd put in the new fluid. Would this work with the Tahoe?
Also, would an external filter system be useful on the Tahoe?
Hardwarz
Old 11-28-2007, 06:57 PM   #8
Mike97
Mike97's Avatar
Default
Hardwarz
No, I replaced the stock transmission cooler with a bigger unit. But you can install it in line with the stocker if you want. I just didn't have the room for both coolers.
I wouldn't recommend pumping out the fluid unless you can figure out a way to replenish it as it's being pumped out. That is exactly what some shops do when flushing transmissions, but they add fluid at the same rate that it is being pumped out. I wouldn't run it low on fluid because it is not good to run the pump dry.
I don't know anything about using an external filter system for an automatic transmission. But you would still want to replace the one in the pan. The fluid has to go through it before going to the pump. If it gets too plugged, your pump will be starved of fluid and burn out. You can't run without it unless you fabricate some kind of pickup tube to replace it, because without it the fluid will not be picked up and the pump will not be able to pump any oil. There is really no easy way around dropping the pan, but a drain plug will definitely help. I installed one in my tranny pan on my old pickup. Make filter changes a lot less messy.
Old 11-29-2007, 12:33 AM   #9
2000 Z71 Tahoe
2000 Z71 Tahoe's Avatar
2000 Z71 Tahoe is on a distinguished road
Default
i dont see why a transmission cooler wouldnt be a bad idea. i have been thinking about installing one myself.
as far as draining it you do have to drop the pan. but the best thing to do would be to take it to your chevy dealer and have them flush the transmission.
Aaron
2000 Z71 Tahoe is offline   Reply With Quote
Old 11-29-2007, 10:15 AM   #10
Hardwarz
Default
I'm a Mobile 1 fan, so a dealer fluid exchange will be pricy. Plus, a lot of the local shops around town use multi-manufacturer ATF fluid. I have found out that there are big differences between the multi-manufacturer transmission fluid and the specific fluids for each car manufacturer. I'm not willing to use the generic ones.
Hardwarz
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
