Register to remove these ads.
Reply
Thread Tools Display Modes
Old 12-20-2007, 07:21 PM   #1
jwpotts0413
jwpotts0413's Avatar
jwpotts0413 is on a distinguished road
Default How to change distributor cap/rotor
anybody got some info on this?
i have the parts on order but haven't looked at doing it.
any info would be most greatly appreciated.
also, any tips on how to remove the stock ignition coil would be awesome.
i have spent several hours trying to figure it out with no luck.
i tried using the dremel to grind out the rivets, even took off the air intake assembly to make more room. still no dice...
jwpotts0413 is offline   Reply With Quote
Old 12-24-2007, 10:48 AM   #2
mygreen98
mygreen98 is on a distinguished road
Default
2 screws hold down the distributor cap, should be phillips head, rotor pushes on. the coil can be removed from the truck completely, via removal with the bracket, then disassembly will be much easier.
mygreen98 is offline   Reply With Quote
Old 12-25-2007, 09:21 AM   #3
jwpotts0413
Default
don't you have to align the rotor to keep from screwing up the timing?
i got the coil out after 2 hours with the dremel and the last little bit with a hammer. my stock coil is mangled but i got the accel in there and it's great. seems to start much easier.
i can get the cap off, but i just didn't wanna touch the distributor aside from changing the wires b/c i have no idea how to set the timing. i know the computer controls it and adjusts everything but i had a mechanic who reinstalled my distributor incorrectly and my hoe ran like sh*t. had to get it towed back to him!
if i can just remove those 2 screws and toss everything in there ill do it myself. i just thought i would see if there is anything i should know before i remove it. mainly because i won't have a ride to work if i put it back together and screw something up.
thanks for the reply, any more info would be great
Old 12-26-2007, 11:01 AM   #4
mygreen98
Default
rotor pull straight off, old one might be on there tight depending how long its been on there. there is a keyway that aligns it on the shaft. just pop old one off and push new one on. thats it.
Old 12-26-2007, 11:03 AM   #5
mygreen98
Default
the distibutor is held down in place by a bracket at its base where it goes into the engine. just pull straight up on the rotor.
Old 01-01-2008, 10:24 PM   #6
jwpotts0413
Default
cool i'll try it on my day off this thursday. thanks for the replies!
:thumbsup:
Old 01-03-2008, 09:03 PM   #7
pinoyesv6
Tahoeforum Noob
pinoyesv6 is on a distinguished road
Default
the two screws that held on my distributor cap were torx screws.
one the cap was off, two more torx screws held on the rotor. as long as you remember how the general way the rotor was pointer you can't screw up the alignment.
pinoyesv6 is offline   Reply With Quote
Old 07-26-2016, 06:07 AM   #8
StreetLife55
Tahoeforum Newcomer
StreetLife55 is on a distinguished road
Default Firing order
I need a good diagram of the firing order of a 99 Che y Tahoe. And where they are connected to the distributor
StreetLife55 is offline   Reply With Quote
Old 08-02-2016, 07:03 PM   #9
lesterl is on a distinguished road
Default
The Cap SHOULD be Embossed from the factory.
lesterl is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
