1. pull the headlights out
2.take off the shroud using a flat head screwdriver to pop the little plastic pins out
3.2 bolts hold on the grill surround, romove these
4. on each side there are to clips directly above the running lamp, you just have to give it a good pull it wont hurt it i promise
5now you have access to your DRL lamps
