Register to remove these ads.
Reply
Thread Tools Display Modes
Old 02-02-2008, 02:25 AM   #1
BClark1204
Tahoeforum Noob
BClark1204 is on a distinguished road
Default oil pan removal
I have a 99 Tahoe 4wd. I am having a lot of difficulty getting the oil pan out. Any suggestions? Do I need to raise the engine? If so, what is the easiest way to this? Thanks for any help!
BClark1204 is offline   Reply With Quote
Old 02-02-2008, 11:50 AM   #2
brodg
brodg is on a distinguished road
Default
Document ID# 332474
1999 Chevrolet Tahoe - 4WD
Oil Pan Replacement
Removal Procedure
Remove the oil level indicator tube. Refer to Oil Level Indicator and Tube Replacement .
Raise the vehicle.
Remove the engine oil and the engine oil filter. Refer to Engine Oil and Oil Filter Replacement .
Remove the oil filter adapter. Refer to Oil Filter Adapter and Bypass Valve Assembly Replacement .
Remove the starter. Refer to Starter Motor Replacement .
Remove the flywheel inspection cover.
Remove the engine mount through bolts. Refer to Engine Mount Replacement .
Raise and support the engine.
Remove the oil pan..
Note the location of any studs to assist reassembly.
Clean all the sealing surfaces. Refer to Oil Pan Clean and Inspect .
Remove the engine oil pan and the gasket.
Installation Procedure
Install the engine oil pan and a NEW oil pan gasket. Refer to Oil Pan Installation .
Lower the engine onto the engine mounts.
Install the engine mount through-bolts. Refer to Engine Mount Replacement .
Install the starter. Refer to Starter Motor Replacement .
Install the flywheel inspection cover.
Install the oil filter adapter. Refer to Oil Filter Adapter and Bypass Valve Assembly Replacement .
Install the engine oil filter and the engine oil. Refer to Engine Oil and Oil Filter Replacement .
Lower the vehicle.
Install the oil level indicator tube. Refer to Oil Level Indicator and Tube Replacement .
Document ID# 332474
brodg is offline   Reply With Quote
Old 02-03-2008, 08:13 PM   #3
41racing
41racing is on a distinguished road
Default
Remove the front diff. it's easy, and they you have great acess to the oil pan.
41racing is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
