Register to remove these ads.
Reply
Thread Tools Display Modes
Old 06-11-2012, 07:29 PM   #1
wesmegan
Tahoeforum Newcomer
wesmegan's Avatar
wesmegan is on a distinguished road
grin AC noise, chirping then vibration when accelerating only
Started with chirping under hood near center of dash on a trip last Monday, only when AC is on and only when accelerating from a stop to about 30mph.
Then, day 2, add a vibrating noise to the chirping, which sounds like something is about to break, and stops if I let off acceleration or turn off AC.
HELP, my husband is outraged that the dealership wants to replace the AC compressor for $1500.
Still blows cold air and my clutch was replaced 50K miles ago. Already tried replacing AC Belt and AC tensioner - no change in noise.
What should I try now? 2001 Chevy Tahoe, 230K miles
wesmegan is offline   Reply With Quote
Old 06-11-2012, 07:55 PM   #2
clkelley
Super Moderator
clkelley's Avatar
clkelley is on a distinguished road
Default
Welcome to the neighborhood!
It MAY be the AC compressor. But when you say you already replaced the ac tensioner, you mean the tensionor pulley? That is what it actually sounds like to me, if it were the compressor (and I am not saying it isn't really) I would tend to assume the ac would falter a little. I honestly have to give the same advice as in another thread, have your husband go purchase a stethoscope style probing tool. Then have him use that tool to "listen" to each of the pulleys and so forth on the front of the engine while it is running. BUT BE CAREFULL not to get into the fan while doing this. Using this method he should be able to better narrow down where the sound is coming from instead of guessing at it...
clkelley is offline   Reply With Quote
Old 06-11-2012, 08:23 PM   #3
wesmegan
Tahoeforum Newcomer
wesmegan's Avatar
Default
Yes, the ac tension pulley & belt were replaced today.
I assumed we had it narrowed down to the ac clutch or compressor, b/c the noise stops when ac is off, even if I leave the interior fan on the noise & vibration noise will stop.
Thanks for replying!
Old 06-11-2012, 08:26 PM   #4
clkelley
Super Moderator
clkelley's Avatar
Default
I would definitely get other quotes on replacing the compressor. Although they aren't cheap, $1500 does seem excessive.
Old 07-23-2012, 11:42 AM   #5
markvdb
Tahoeforum Newcomer
markvdb is on a distinguished road
Default
It took 2400 to fix mine. If the chirping just started, DO NOT run the ac until it is fixed. Your compressor is slugging. Take it to a shop and have them check the inline filter. If there are no metal shavings in the filter, replace the compressor with a new Denso model. DO NOT use 4 seasons, I went through 3 of those. When the compressor is replaced, have them double check the oil level in the system. A small low oil condition can cause slugging. You can add oil if there is no shavings, but I would advise the new denso compressor, it is redesigned. IF there are metal shavings in the filter, the system will need flushed. I waited too long and had to replace the condensor, evaporators, everything. Do not wait, and do not run the ac until it is repaired.
markvdb is offline   Reply With Quote
Old 05-26-2014, 01:08 PM   #6
Onatebuawer
Tahoeforum Newcomer
Onatebuawer is on a distinguished road
Default
I think that*this information is*the best.
dubli
Onatebuawer is offline   Reply With Quote
Reply
Bookmarks
Tags
ac noise, chirp, vibration
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
