Register to remove these ads.
Reply
Thread Tools Display Modes
Old 04-06-2013, 11:07 AM   #1
lone ranger
Tahoeforum Newcomer
lone ranger is on a distinguished road
Default Whats the secret to installing sway bar links
I've got a '99 4X4 and the right sawy bar link snapped. I ordered ACDELCO replacement parts kit (2 links) figuring that if one snapped the other can't be far behind. I was able to get the link and bushings in place but can't compress the bushings enough to thread the nut. So far the end of the link is flush with the bottom of the lower bushing washer.
My question:
Is there a special tool or secret to compressing the bushing to thread the nut?
lone ranger is offline   Reply With Quote
Old 04-06-2013, 01:52 PM   #2
Bigbill
Tahoeforum Apprentice Member
Bigbill is on a distinguished road
Default
Use a pry bar and pull down while threading the nut by hand
Bigbill is offline   Reply With Quote
Old 04-06-2013, 06:01 PM   #3
lone ranger
Tahoeforum Newcomer
Default
Thanks. Friend came over. Took off the wheel and we stuck a long pry bar between the top nut of the link and the rod above the sway bar. While one of us lifted up on the pry bar, thus pushing down on the link, the other was able to thread the other end. We also used a 5 inch conduit pipe placed thru the lower control arm opening and hammered the lower bushing making sure it was as far up on the threads as possible. Once threaded all went well.
I had a '87 Buick Regal and changed the front sway bar and links and it wasn't as near as hard as doing the Tahoe, and I did it alone.
Thanks again.
Old 07-21-2013, 02:26 PM   #4
buskeyl
Tahoeforum Newcomer
buskeyl is on a distinguished road
Default
So we tried to do this and it has been complete PITA. There is only a small hole in the lower control arm to access the head of the bolt, and the hole is not lined up with the bolt, so you cant get a socket on it. If you try to install the bolt head up. like they were before we cut them out, there's no way to get the bolt in because the upper control arm us position directly over the top of the end of the sway bar link, so there no way to get the bolt in there with the upper control arm in the way. We are starting to think something is bent. I got the right side done somehow. When we decided to start over, thinking you might have needed to have both ends started before you tightened either end down hard, we rounded the both hard off, due to the issue with he hole in the lower control arm I mentioned earlier. This is a 95, 2 door Tahoe 4x4. How are we supposed to get a grip on this bolt head with it off center from the access hole>?
buskeyl is offline   Reply With Quote
Old 07-21-2013, 05:10 PM   #5
amtronic1
amtronic1's Avatar
amtronic1 is on a distinguished road
Default
You got something bent. The sway bar should be easy as pie to bolt up assuming you are on level ground.
amtronic1 is offline   Reply With Quote
Old 07-21-2013, 09:48 PM   #6
aznpersuasion
aznpersuasion is on a distinguished road
Default
honestly i took my end links out and have have better ride quality. its a 5000 pound beast and shouldnt be taking corners hella fast anyway. i say just leave it uninstalled.
aznpersuasion is offline   Reply With Quote
Old 07-31-2013, 02:03 AM   #7
DennisW
Tahoeforum Newcomer
DennisW is on a distinguished road
Default
Quote:
bad suggestion. Being a top heavy truck sway bars do an important job of reducing body roll even at low speeds and especially in any sort of avoidance maneuvers. They're there for a reason, just unhooking them because it's a bit difficult to service them properly isn't the right, or safe, answer
DennisW is offline   Reply With Quote
Old 07-31-2013, 02:04 AM   #8
aznpersuasion
Default
Quote:
couldnt agree more.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
