Go Back   Tahoe Forum - Chevy Tahoe Forum > 2000 - 2006 Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > Audio, Video and Alarm Discussions
Register to remove these ads.
Audio, Video and Alarm Discussions This forum is for discussing audio and video topics. Such as upgrading or repairing your A/V system.
Reply
Thread Tools Display Modes
Old 03-07-2008, 10:57 PM   #1
medic-04
Tahoeforum Noob
medic-04 is on a distinguished road
Default no sound from aftermarket stereo
I have a 2001 yukon xl with onstar that is not used. I bought a new aftermarket stereo and installed with provided harness adapter. Power comes on and everything seems to work on the HU, but there is no sound. I searched around the web for anyone that might have the same problem but came up with only a few similar questions. the understanding i have is that the factory amplifier will conflict with the preamp built into the aftermarket stereo. but how do you bypass the preamp? The remote antenne is hooked up to the remote wire on the harness, but nothin'. Now there is the main harness input on the factory radio, and there is another 10 or so pin harness that also attatches to the back of the factory radio. There is nowhere for this other 10 pin connector to go on the aftermarket unit or harness adaptor. Is this related ? Someone PLEASE help!!!
medic-04 is offline   Reply With Quote
Old 03-08-2008, 08:46 AM   #2
Design
Design is on a distinguished road
Default
Do you have the factory BOSE system? If so that is how you should search. I have not run into the exact problem you have (still have factory head unit) but at least I can help point you in the right search direction.
Design is offline   Reply With Quote
Old 03-08-2008, 10:58 AM   #3
greengumby
greengumby's Avatar
greengumby is on a distinguished road
Default
That "10 pin" harness is your aux features like the Xm radio ,onstar, DVD player , ETc. etc.. you should pull out your harness and re-verify that you are tapped into the speakers from your HU to the truck. Sometimes I have noticed if you use a harness thats non onstar with an onstar system the wiring is different.
even though you dont use onstar you still have the hardware hooked up. so thats why i said to verify from the HU that you are running into the correct audio wires to the truck through the harness. chances are you may be just tapped into the wrong wire simple fix ...
greengumby is offline   Reply With Quote
Old 03-08-2008, 12:08 PM   #4
JKmotorsports's Avatar
JKmotorsports is on a distinguished road
Default
On the 10 pin harness, you will need to power the pink wire. Run the remote turn on from your new stereo to this wire.
JKmotorsports is offline   Reply With Quote
Old 04-01-2008, 02:36 AM   #5
tattootrig
Tahoeforum Apprentice Member
tattootrig's Avatar
tattootrig is on a distinguished road
Default
Hi all... this is my first post here and I am sure it will not be my last. I just installed an aftermarket into my '02 and like this thread, had no sound. I used the pink wire jump like JK suggested and it now works like a champ. My question is, is it possible to get the onstar and the rear passenger controls to still work? The secondary controls are not that important, just seems strange to have something there that does not work.
Thanks alot guys, and thanks for a great forum.
Trigger
tattootrig is offline   Reply With Quote
Old 12-27-2016, 05:20 PM   #6
Ron02Tahoe
Tahoeforum Newcomer
Ron02Tahoe is on a distinguished road
Default
Thanks for the help. Tapping into the pink wire worked.
Ron02Tahoe is offline   Reply With Quote
Old 12-27-2016, 10:36 PM   #7
Spykedamonsta
Tahoeforum Newcomer
Spykedamonsta is on a distinguished road
Default
Well can someone please help me? By the way I'm new and im SPYKEDAMONSTA I have a 1999 yukon denali and it has the bose factory system in the head unit has a tape player with a cd player below it , and in the console there's a cd changer. What I want to know is it bought a new head unit a 7 inch flip out screen but the problem is it has no REMOTE WIRE, I keep watching videos and reading the same thing cut into the pink wire and tie the blue/white wire around it and it will work but do to me not having the blue / white wire how will I get it to work???????
Spykedamonsta is offline   Reply With Quote
Old 03-05-2017, 12:48 PM   #8
Mike.yan22
Tahoeforum Newcomer
Mike.yan22 is on a distinguished road
Default
I have a 2004 Chevy tahoe and I am trying to put I a new ddin head unit. I have a bose factory stereo in now with on star and rear entertainment. I had bought the rp5-gm11 Interface to keep the chimes and on star. I connect the rp5 Into the harness with went into the back of factory radio but can't not get no sound.
I don't know own if I have to remove the old amplifier if I do what do I do with the wire that could next I to it
Somebody please help me
Mike.yan22 is offline   Reply With Quote
Old 05-12-2017, 09:23 AM   #9
jkslade1985
Tahoeforum Newcomer
jkslade1985 is on a distinguished road
Default
Former car audio installer here. Whenever we had a factory system we would do one of two things. Either run new wire to all the speakers (this was usually for smaller cars) or we would search for the factory amp disconnect it and start narrowing down what wires lead to speakers on the output with the 9v test.
In case you don't know the 9v test, you take a 9v battery and touch 2 leads to the terminals. This will cause the speaker to make an audible pop. Once you hear the pop you will want to look at the speaker that made the noise to see what direction it pops. If it pops out you have the correct polarity on the wires. If it pops out you will need to reverse the wires to have the positive and negative wires ran correctly.
Once you have figured out which speakers go to what wires you can run new wires from the aftermarket harness to the correct wires.
From the harness:
White is front driver side
Gray is front passenger
Green is rear driver side
Purple is rear passenger
Hope this helps. Good Luck!
jkslade1985 is offline   Reply With Quote
Old 05-16-2017, 02:00 PM   #10
Torey
Tahoeforum Newcomer
Torey is on a distinguished road
Default If you could help
Hey guys i have a 2002 Tahoe. No on-star or Bose just factory sub and amp. I wired the aftermarket radio and plugged it up. It turns on but no sound. I did research and everybody is saying on the second harness there is a pink wire. Problem is i do not have a second harness. I really do not want to take it to a shop and i can do it myself. Can some please help me.
Torey is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
