Register to remove these ads.
Reply
Thread Tools Display Modes
Old 03-11-2008, 12:39 PM   #1
tahoefuz
Tahoeforum Apprentice Member
tahoefuz is on a distinguished road
Default Blown head gasket?
What are the chances that with a blown head gasket the fluid that gets into the cylinders cause the motor not to crank due to the pressure? And what are the chances of having a cracked block or head also?
tahoefuz is offline   Reply With Quote
Old 03-11-2008, 01:18 PM   #2
blk87brd
blk87brd is on a distinguished road
Default
Chances are pretty good that a blown head gasket could allow coolant to enter cylinder and not to crank. Pull the plugs and check for wet. With the plugs out crank the engine over to clear coolant from cylinder. Put the plugs back in and crank while watching fluids in rad. You may well see evidence that compression is getting into the water jackets. As a rule of thumb (and all rules have exceptions) heads crack from overheating and blocks crack from freezing. Any history of either?
Regards
Tom G.
blk87brd is offline   Reply With Quote
Old 03-11-2008, 03:34 PM   #3
tahoefuz
Default
never over heated, never frozen. But there was an extreme amount of smoke coming out of the pipes just before the motor shut off. but still no over heating.
Old 03-11-2008, 03:51 PM   #4
blk87brd
Default
White smoke? I'd do a compression test on each hole to determine which one (s) is the likely candidate. My guess would be a blown head gasket, but I would have a really good look at the head gasket when I got it out to make sure that it was the gasket and not the head. If I wasn't positive I would have the head magna fluxed or whatever to look for cracks. Changing head gaskets should keep you amused for a Saturday.
Old 03-11-2008, 09:02 PM   #5
tahoefuz
Default
Thanks for the input, I'm gonna pull the heads off tomorrow and do the gaskets. And I guess my best bet would be to just buy heads, or plan on having these refreshed.
Old 03-11-2008, 10:44 PM   #6
Black96
Black96's Avatar
Location: willamsport PA (college) souderton Pa ( home)
Black96 is on a distinguished road
Default
if so before u take the head off check ir intake manifold gasket those are known to leak, i had the same problem and just fixed it this weekend, and the smoke could be to much gas or coolant in the motor, check engine light on?
Black96 is offline   Reply With Quote
Old 03-12-2008, 12:25 AM   #7
Mike97
Mike97's Avatar
Mike97 is on a distinguished road
Default
Quote:
If the block never froze or overheated, odds are that you have a blown head gasket. How many miles are on the engine? It would be a good time to refresh the heads if your engine is tired.
Mike97 is offline   Reply With Quote
Old 03-13-2008, 03:21 PM   #8
tahoefuz
Default
well, as it turns out, and this is my luck, the block is siezed, plugs are pulled and the motor won't go anywhere. time for a new motor. Thanks for the help anyway guys.
Old 03-13-2008, 03:38 PM   #9
blk87brd
Default
Cosider this for whatever it's worth. I once saw a guys pour Rust Check down the cylinders of a siezed engine, left it for a day, came back started it up and drove it for over a year (and maybe longer, I moved) with no problem. Mind you it was a 265 inline chev. BUT?? What is the downside, if it works you've ought some time, if not you've lost the price of a couple of cans of Rust Check. Next question, who sells Rust Check now.
Here is their site: http://www.rustcheck.com/
Hope this helps, new engines are not cheap.
Old 03-13-2008, 04:47 PM   #10
Black96
Black96's Avatar
Default
thats a bummer man, should look into the gm's 383's haha
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
