You have a 99 tahoe - than most likely you already have the second battery tray located on the drivers side of the vehicle.. all you need to do, is go to a parts yard, and find the rubber peice that holds the battery in, than go to autozone, get the longest cable you can find.. * i have two top, and side post batteries so, this was easy for me, on the factory battery, if top post, it is very easy to get a top post battery cable, and put it on the postive of the factory battery - if not, than turn the cable around, and make sure you get a top and side for the new batt - the factory already has an exended postive sidepost bolt, just hook the new positive wire to it(if u dont have a top post to hook it too) - and hook the other side to the positive on the new batt (or get the PAC-200 and wire it in) wire the Neg on the new batt to a bolt found around the Power steering pump on the motor - wire your amp in and your good to go
