Go Back   Tahoe Forum - Chevy Tahoe Forum > 2000 - 2006 Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > Technical write ups & Installation Guides
Register to remove these ads.
Technical write ups & Installation Guides This forum is designated to post technical "how to" install guides to assist others with modding thier Hoes
Reply
Thread Tools Display Modes
Old 04-18-2008, 08:47 PM   #1
tspain
tspain is on a distinguished road
Default Tech: Intermediate Shaft Replacement
If you have a GMT800 body style truck/SUV you probably know about the intermediate steering shaft making the horrible knocking/popping when turning and going over bumps.
Here's a little walkthrough to help you replace that steering shaft with the new designed, non-greased, steering shaft. Part number 19153614
Important:
I-shaft P/N 19153614 has been designed to replace previous designed dampened and non-dampened I-shafts. The physical difference in the yoke size will accommodate all vehicles listed in this bulletin.
Due to the design of the new I-shaft, it is not possible to lubricate/grease the I-shaft.
Set the front wheels in the straight ahead position.
Notice: On the 2002 and later model year vehicles, the steering column LOCK was removed from the steering column. It is critical that the J 42640 - Steering column Anti-Rotation Pin is used when servicing steering columns on 2002 and later model year vehicles. Failure to use the J 42640 may result in damage to the SIR coil.
Set the steering wheel in the LOCK position on 2001 and prior model year vehicles.
From under the hood, remove the lower bolt that connects the upper intermediate shaft to the steering gear coupling shaft.
Slide the shaft towards the dash in order to disengage the shaft from the steering gear coupling shaft.
For vehicles equipped with adjustable foot pedals, perform the following steps:
1. Reposition the carpet away from the accelerator pedal position (APP) sensor.
2. Remove the two nuts retaining the accelerator pedal to the bulkhead.
3. Reposition the accelerator pedal out of the way so the intermediate shaft can be removed.
From inside the vehicle, remove the upper bolt from the upper intermediate steering shaft (1) to the steering column connection.
Remove the upper intermediate steering shaft assembly.
1. From inside the vehicle, slide the shaft down and off the steering column.
2. From inside the vehicle, slide the upper intermediate shaft through the dash boot seal and remove the shaft from the vehicle.
Replace the upper intermediate shaft.
Install the upper intermediate steering shaft through the dash boot seal and slide the lower end into the steering gear coupling shaft.
Raise the upper end of the intermediate steering shaft and install into the steering column shaft.
Install the upper bolt and nut.
2008 General Motors Corporation. All rights reserved.
tspain is offline   Reply With Quote
Old 04-19-2008, 04:28 AM   #2
DutchTBI
Tahoeforum Apprentice Member
DutchTBI's Avatar
DutchTBI is on a distinguished road
Default
There's a much cheaper fix for this. Just loosen the lowest bolt on the ISS so that it comes apart from the part below. Gently push the ISS in and out towards the firewall for a few minutes, re-install the lowest bolt and presto, you're set for amother rattle free 10.000 miles or so. Works like a charm. See:
http://www.silveradoss.com/forums/in...howtopic=31625
DutchTBI is offline   Reply With Quote
Old 04-19-2008, 08:11 PM   #3
tspain
Default
I'm aware of that fix as it was the temporary fix we were to do while GM was manufacturing the new designed shafts. If you replace the shaft with the new design one, you won't have to worry about it any more.
Alternatively, on the old style (greased) shafts, you can drill a hole in the upper part of the shaft and install a grease fitting and squirt a shot or two in it every time you change your oil.
Old 04-20-2008, 09:49 PM   #4
greengumby
greengumby's Avatar
greengumby is on a distinguished road
Default
Quote:
Great!..now this would be what...grease zerk Number 12? to be done ...:smilielol: :smilielol:
greengumby is offline   Reply With Quote
Old 09-30-2008, 10:49 AM   #5
rcaballe
Tahoeforum Noob
rcaballe is on a distinguished road
Default Heeeeeeeeelp! My Child Turns Steering Wheel Wiht Iss Removed!!!
Hi there!!!
My child turns the steering wheel while ISS is away. So right now, steering controls and air bag don't work??? What I can do?? is possible to coil is ok or is sure that it was damaged??? I need opinions, thank you in advance,
Ruben
rcaballe is offline   Reply With Quote
Old 09-30-2008, 10:50 AM   #6
rcaballe
Tahoeforum Noob
Hi there!!!
My child turns the steering wheel while ISS is away. So right now, steering controls and air bag don't work!!!
Ruben
Old 10-03-2008, 05:11 PM   #7
jonbert
Tahoeforum Noob
jonbert is on a distinguished road
Default
Ouch. I couldn't tell you but I guess I will buy the anti rotation pin before I try installing my ISS.
jonbert is offline   Reply With Quote
Old 11-09-2008, 06:59 PM   #8
VaTahoeLt
VaTahoeLt's Avatar
VaTahoeLt is on a distinguished road
Default
just finished installing my new ISS. Talk about a pain in the ass to get the gas pedal assembly bolted back up
VaTahoeLt is offline   Reply With Quote
Old 11-10-2008, 11:23 AM   #9
jonbert
Tahoeforum Noob
Default
It does take a little finesse. If you didn't use a 3/8 universal with extension I don't know how you can do it.
Old 11-12-2008, 12:12 PM   #10
dpnut2
dpnut2's Avatar
dpnut2 is on a distinguished road
Default
On my '05 tahoe (bone stock) I can also feel the the road or bumps up through the steering column and right to my steering wheel, so I am thinking of getting this done or doing it myself.
On a scale from 1-10...how hard is this to do if I have never done this type of work before?
Thanks
dpnut2 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
