Register to remove these ads.
Reply
Thread Tools Display Modes
Old 04-21-2008, 04:28 PM   #1
maswindell
Tahoeforum Apprentice Member
maswindell is on a distinguished road
Default Replacing Oil Pressure sending unit
I have an 04 Tahoe with the 5.3 motor and the oil pressure is either zero or over 100. There's plenty of oil and I assume the sending unit is bad. The Haynes manual is pretty bad as far as location. Where is it located ? I searched the top of the engine with no luck, is it underneath somewhere ?
Thanks
Mike
maswindell is offline   Reply With Quote
Old 04-21-2008, 05:43 PM   #2
maswindell
Default
The local speed shop said the sender is by the oil filter - put the truck up on ramp and there is a fitting there but no sending unit. Where else do I look ?
Old 04-21-2008, 08:22 PM   #3
lskipper
lskipper is on a distinguished road
Default
My 04 Tahoe had the same issue, except it stayed pegged over 100. The dealership replaced the gauge cluster. No problems since. If you think it is the oil pressure sensor, then check Haynes or Chiltons, they should be able to detail how to check the switch to see if the issues is there.
lskipper is offline   Reply With Quote
Old 04-23-2008, 04:32 PM   #4
TXHorn
Tahoeforum Noob
TXHorn is on a distinguished road
Default
My '03 has a similar issue: oil press warning came on & OP read zero, and then popped up to 80 (max on gauge). Never happened before & was about time for an oil change so I did so about a week ago. It then happened again (drop to zero, warning on, then back up to 80). Since I know the oil is fresh & full and the fact that it drops suddenly only to go back to normal, sounds like a sending unit/switch issue, or possibly a loose ground wire?
Found a new switch online for $30-36, but could use some help locating it as well.
TXHorn is offline   Reply With Quote
Old 05-02-2008, 12:13 PM   #5
kevincoop
Tahoeforum Noob
kevincoop is on a distinguished road
Default
TX Horn,
Where did you find the pressure switch online. I have the same problem with an 06 I just bought and would like to try a 30 dollar part before having someone look at it.
They have mine at the dealership so I cant look for it, but if I find it when I get it back, I'll post.
kevincoop is offline   Reply With Quote
Old 05-03-2008, 11:04 PM   #6
lskipper
Default
For a 04 Tahoe. Hope this helps.
Old 05-04-2008, 06:02 PM   #7
maswindell
Default
thanks for the pic, I'll take a look see and see if I can find it/
Cheers
Old 05-04-2008, 08:08 PM   #8
thearch
thearch is on a distinguished road
Default
I would check with your local dealership on this issue. They had a recall on the gauge clusters in 2003 and 2004 models due to diffective clusters. I don't remmember how long they were honering this recall but making a phone call never hurts.
thearch is offline   Reply With Quote
Old 05-07-2008, 01:43 AM   #9
tspain
tspain is on a distinguished road
Default
The Special Coverage Adjustment for the IPC is 7 years, 70,000 miles, whichever comes first.
Call the dealer and give them your VIN and see if your truck is covered, or you can PM me your VIN and I'll check for you.
tspain is offline   Reply With Quote
Old 10-27-2008, 02:40 PM   #10
mstephens3701
Tahoeforum Noob
mstephens3701 is on a distinguished road
Default
What part of the engine are we looking at in this picture? Is it the upper rear?
mstephens3701 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
