Register to remove these ads.
Reply
Thread Tools Display Modes
Old 05-04-2008, 11:56 PM   #1
Armycop
Tahoeforum Apprentice Member
Armycop's Avatar
Armycop is on a distinguished road
Default Removing the fan clutch from my water pump
Is a pain in the ass! I couldn't get enough tension on the belt to hold the bell pulley in place as I turned on the clutch fan nut (big mutha too). So, in desperation, I pulled the water pump assembly out. So now I've got the bad pump out with the fan and clutch assy. still attached!! Any ideas??:confused2:
Armycop is offline   Reply With Quote
Old 05-05-2008, 11:05 AM   #2
Armycop
Armycop's Avatar
Default
C'mon, anybody?? Thunder?
Old 05-05-2008, 12:28 PM   #3
JKmotorsports's Avatar
JKmotorsports is on a distinguished road
Default
You need some special tools:
J 41240 Fan Clutch Remover and Installer
J 41240-5A Fan Clutch Wrench
One tool goes into the two holes on the front of the pulley to keep the pulley from turning as the other is loosening the hex shaped bolt behind it.
JKmotorsports is offline   Reply With Quote
Old 05-05-2008, 02:02 PM   #4
Armycop
Armycop's Avatar
Default Aha
I knew those holes in the pulley were there for a reason!! Guess I'll take it to my GMC dealer and see if they can hook me up. Thanks JK!
Old 05-05-2008, 10:56 PM   #5
greengumby
greengumby's Avatar
greengumby is on a distinguished road
Default
Quote:
WOW i must say your the first that actually I have seen to take the whole assembly off including the fan clutch
good job though !!!!
greengumby is offline   Reply With Quote
Old 05-05-2008, 11:21 PM   #6
Armycop
Armycop's Avatar
Default
Wasn't hard, I removed the fan shroud and then accessed the six 10mm bolts using my long socket and air wrench. Almost fell out!
Thanx tho!:shy:
Old 05-06-2008, 10:50 PM   #7
Armycop
Armycop's Avatar
Default Update: I'm done
I took the old and new water pumps to a local shop, where they took an air chisel to the nut and rap-rap-rapped it right off! Then I had them install it on the new pump, samey-styly!
Got home this evening and it took me less than 1/2 hour to button everything back up! Liberal use of RTV too, just to make sure. Oh, torque on the six bolts is 11ft.lbs first pass, 22 ft.lbs second pass. CAREFUL: The bolts are aluminum going into an iron block; they will stretch, then break real easy! I used a 'lil over two gallons to refill the cooling system (dry it holds 16 quarts; that's four gallons). Took the girl out for a spin to warm up the engine, and whaddya know, no drips, runs or errors! Any easy project for any home mechanic with hand tools too. I've got air power, so it went a little faster.
Old 06-03-2010, 08:36 PM   #8
lestep01
Tahoeforum Noob
lestep01 is on a distinguished road
Default Water Pump fan assembly 1999 Tahoe 5.7 v8
I did the same thing. I got frustrated and pulled the old water pump off with the fan, clutch, and pulley still attached. I ended up buying a new fan, clutch, and pulley for the new water pump because I broke two of the fan blades fooling with it and the total price for all three parts was just over $100. The parts store told me there was a special tool to remove the fan, but they could not find it in their catalog (Napa Auto Parts, Memphis, TN).
I also need to repair the lower intake manifold gasket, but I started with the water pump and radiator hoses to elliminate sources of leaks. My Tahoe started leaking/using coolant a year ago at a rate of about a gallon every three weeks until this week it was up to 1 gallon a day, so I thought I had better do something about it. The local shop wanted $650 just to repair the intake manifold gasket and the water pump was extra on top of that. I figure I could save some money by doing the water pump myself, but I had not anticipated the trouble I had with the fan assembly.
I am not confident I can do the intake manifold gasket because of all of the linkages, wires, gas lines, etc. that have to be removed from the top of the manifold. I looked at the throttle lnkage and could not figure out how to disconnect the cables from the throttle body without breaking them. I guess I need a shop manual. Helm wants $300 for the DVD new, but I saw a DVD shop manual on eBay for $50, I just don't know if I can trust someone on eBay not to rip me off. I also saw the set of paper shop manual for $50 on eBay. Is the DVD better? It appears to have been revised since the paper manuals were printed.
lestep01 is offline   Reply With Quote
Old 06-03-2010, 08:57 PM   #9
lestep01
Tahoeforum Noob
Default 1999 Tahoe water pump and fan assemble
The new water pump and fan clutch that I bought at Napa Auto Parts is not reverse threaded. Are some of them reverse threaded and others not?
I have the heavy duty fan since I have the towing package, 4WD, and air conditioning, so I believe the fan is supposed to rotate in reverse direction. Did the parts store sell me the wrong water pump if it is not reverse-threaded?
Old 11-05-2010, 07:08 PM   #10
Darkitec
Tahoeforum Newcomer
Darkitec is on a distinguished road
Default
You can buy the spanner wrench online for about $25 A whole lot cheaper than the $100+ my local Stealership wanted to charge to remove the clutch from mine. The wrench is one heavy piece of steel will last a lifetime. Took me all of 15 min from raising the hood to closing the hood to replace the fan clutch. Stealership sure thinks very highly of their mechanics to charge that much for 15 min. of work.
Darkitec is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
