Go Back   Tahoe Forum - Chevy Tahoe Forum > 2007 + Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > General Tahoe/Yukon/Escalade Discussion Forum
Register to remove these ads.
General Tahoe/Yukon/Escalade Discussion Forum General Discussion Forum
Reply
Thread Tools Display Modes
Old 06-03-2008, 06:22 AM   #1
wongs83
Tahoeforum Apprentice Member
wongs83 is on a distinguished road
Default power liftgate won't go past 3/4 up
On my 07 the other day when I went to use the power liftgate and it would only go up between 1/2 and 3/4 of the way and then it would come back down almost like it had came in contact with something. I did it about 15 times and tried to watch and listen to see what the problem could be. I don't know if this was the case before, I don't think so, but I noticed it almost looks as the the liftgate it shifted towards the passenger side. The reason I first noticed it was there is a little spot on the bumper by the tailight on the passenger side where the liftgate rubs when it comes back down. I also noticed now when the liftgate is closed it is right up against the passenger side tailight, but on the driver side I have almost a 1/4" gap.
Any thoughts here?
wongs83 is offline   Reply With Quote
Old 06-03-2008, 08:32 AM   #2
smoothfrc
smoothfrc is on a distinguished road
Default
My liftgate rubbed the bumper also, had it back to the dealer twice and the only thing they do is shift the bumper over. They say they have no way of adjusting the liftgate and how it works.
I imagine in your case, hopefully they can look at replacing the motor.
What happens if you manually lift the gate up all the way? is there any resistance where it stops? will it pull it all the way down when it is up?
smoothfrc is offline   Reply With Quote
Old 06-03-2008, 08:44 AM   #3
wongs83
Default
Is there a way to manually lift it?
The only way I was able to even get in it was after the liftgate raised 1/2 way and then started back down if I grabbed the gate and applied some pressure it would "pop". It seemed to take an awful lot of holding pressure to even stop the liftgate (more then what seemed safe and would probably break a bone on a kid before it stopped) and after this "pop" the lift gate could be raised and lowered manually but it was VERY heavy and seemed to have no assitance from the rods on each side. As a matter of fact it was hard for my wife to even hold up the liftgate while I drug baseball equipment out of the back. And when you would let the door go LOOK OUT because it would slam shut!
To be honest I"m starting to get a little disappointed in my tahoe. I've had it in the shop for radio problems, rattles in the top, rear defrost problems, defective rim problems and now the liftgate. Probably the most expensive vehicle I have purchased and by far the most problems.
Old 06-03-2008, 11:19 AM   #4
aaron72
aaron72 is on a distinguished road
Default
On the headliner right in front of the rearview mirror should be a switch where you can turn off the power liftgate. Do that and then go to the gate and open it up and see if you can lift it all the way up or if you experience any resistance before you get fully extended.
aaron72 is offline   Reply With Quote
Old 06-03-2008, 11:30 AM   #5
Gambler
Gambler's Avatar
Gambler is on a distinguished road
Default
If it is under warranty take it into the dealer, sounds like a bad motor. I surely wouldn't force it unnecessarily.
Gambler is offline   Reply With Quote
Old 06-03-2008, 11:40 AM   #6
wongs83
Default
Thanks for the responce. I actually went out and tried it and the liftgate iss really shifted over and rubs on the edge of the bumper as well as the edge of the tailight, but I don't think it has anything to do with the problem, but rather may a seperate problem that is caused by the liftgate not working.
I can lift the gate by hand and it doesn't seem to have any type of hangup anywhere, but it is heavy to raise. SHouldn't the assist shafts on each side be helping this go up when raising by hand. I have a pacifica that has a liftgate like this and it's not power, but when you open it and it gets about 1/2 way up the assist shafts on the side raise it and keep it up. On the tahoe I'm having to muscle it up and hold it up or it will come slamming down.
Old 06-03-2008, 11:41 AM   #7
wongs83
Default
Of course it's not under warranty, nothing happens when it's still under warranty. I'm at about 41,000 miles.
Old 06-03-2008, 12:56 PM   #8
smoothfrc
Default
It should not be difficult to open... The shock's may be bad? (maybe just one of them)... That may explain why it only goes up to a certain point.
I dont believe they are very expensive to replace.
Old 06-03-2008, 01:03 PM   #9
wongs83
Default
It could very well be the problem. I went out and looked at them again and the driver side shock looks as though it has been leaking down the side of the opening where it is mounted on the bottom.
Anyone changed these before that can share a trick or two? Otherwise they look pretty self explanitory.
Old 06-03-2008, 01:29 PM   #10
smoothfrc
Default
I am curious if this will also resolve your issue with the gate hitting the bumper/tail light.
Please report back.....
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
