Register to remove these ads.
Reply
Thread Tools Display Modes
Old 06-30-2008, 08:01 PM   #1
YukonJacks
YukonJacks's Avatar
YukonJacks is on a distinguished road
Default Intermediate Shaft Replacement How hard is it
How difficult is it to change out?
I have a 2000 Yukon
I read a thread provided be tspain, I'm not sure about a few things he discussed.
Notice: On the 2002 and later model year vehicles, the steering column LOCK was removed from the steering column. It is critical that the J 42640 - Steering column Anti-Rotation Pin is used when servicing steering columns on 2002 and later model year vehicles. Failure to use the J 42640 may result in damage to the SIR coil.
What is a J 42640 and where is it located?
Remove the upper intermediate steering shaft assembly.
1. From inside the vehicle, slide the shaft down and off the steering column.
2. From inside the vehicle, slide the upper intermediate shaft through the dash boot seal and remove the shaft from the vehicle.
Replace the upper intermediate shaft.
Install the upper intermediate steering shaft through the dash boot seal and slide the lower end into the steering gear coupling shaft.
Raise the upper end of the intermediate steering shaft and install into the steering column shaft.
I dont understand what has to be done from inside the vehicle?
Any clarification would be greatly appreciated
Bill
YukonJacks is offline   Reply With Quote
Old 06-30-2008, 08:41 PM   #2
JennaBear
JennaBear's Avatar
JennaBear is on a distinguished road
Default
Not very difficult at all. We changed the shaft in the SSS after the dealer failed twice to fix the problem.
__________________
http://www.blackbearperformance.com/images/Signatures/JennaBear_L.gif
Some Show and Some Go
Performance Tuning and Parts Dealer
JennaBear is offline   Reply With Quote
Old 06-30-2008, 08:47 PM   #3
YukonJacks
YukonJacks's Avatar
Default
and
Old 06-30-2008, 08:54 PM   #4
JennaBear
JennaBear's Avatar
Default
If you have your head under the driver side dash, you should be able to see the bolt that attaches to the int. shaft about a foot above the brake pedal. Lemme know if that helps.
Shouldn't take long, maybe 10-20 mins depending on your comfort level with mechanical stuff
__________________
Old 07-01-2008, 01:16 AM   #5
east302
east302 is on a distinguished road
Default
The J42640 is a little tool that you stick in a hole in the steering wheel to keep it from turning:
http://www.etoolcart.com/index.asp?P...OD&ProdID=9541
You could probably find it at an Autozone or somewhere like that. But, since you have a 2000 and the tool is for 2002+, don't worry about it. It's really just to make sure your kids don't jump in there and turn the hell out of the wheel when the shaft is removed.
I did it on our old 2000 Tahoe and thought it was fairly simple. Took about an hour since it was the first time and everything that could get stuck got stuck. Patience is not one of my strongpoints.
In tspain's post...
http://www.tahoeforum.com/showthread.php?p=58503
the first picture shows the bolt connection at the shaft under the hood. It's easy to get to, but can be a little hard to undo since the bolt is exposed to the elements. When the bolt is removed, you have to pull the two sections apart. Again, kind of hard to do if they're stuck real bad and it's hard to get a good grip on them anyways.
The second picture shows the shaft as if you were looking through the firewall toward the front seat. The bolt is not clearly indicated on the drawing but I tried to draw an arrow to it and attach a copy of tspain's picture....it'd probably be easier to look up under the dash to see where it is.
When that's unbolted, you have to pull the entire shaft out through the inside. There's a rubber boot at the firewall and the shaft will telescope but it'll eventually come through. It's a tight fit.
Good luck,
Scott
east302 is offline   Reply With Quote
Old 07-04-2008, 11:06 PM   #6
YukonJacks
YukonJacks's Avatar
Default
Do I need to disconnect the battery and disable the airbags first???
Old 07-04-2008, 11:18 PM   #7
east302
Default
No, you're fine leaving them connected.
Here's a link to another forum:
http://z71tahoe-suburban.com/iboard/...?showtopic=181
The very first post has a pdf attachment that, when opened, shows good pictures of the steering shaft removal. The rest of it is for the lube, which you can ignore. You might have to register at the site to see the file, I'm not sure.
Hope this helps,
Scott
Old 07-04-2008, 11:35 PM   #8
YukonJacks
YukonJacks's Avatar
Default
for some reason I can't find the pdf attatchment
Old 07-05-2008, 01:25 AM   #9
east302
Default
You have to register (log-in) to that forum. When you do, you'll see the post by "carguru" where he says "Here is the complete procedure" and the pdf file is a link just below that sentence.
If you can't get it, it's not critical...just has a few photos of the ends of the shaft which show where the bolts are. Otherwise, you're probably ok with what you have so far.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
