Register to remove these ads.
Reply
Thread Tools Display Modes
Old 07-23-2008, 10:58 PM   #1
fletch57
Tahoeforum Newcomer
fletch57's Avatar
fletch57 is on a distinguished road
Default Service 4wd Problem
I am new and hope I'm in the right place. I have a 1998 tahoe that is stuck in 4wd and the "service 4wd" light is on. The LED's on the push button switch are off. Please help!
fletch57 is offline   Reply With Quote
Old 07-24-2008, 01:47 AM   #2
BoostJunkE
Tahoeforum Noob
BoostJunkE is on a distinguished road
Default
Quote:
I'm not a fan of the new electronic 4WD switch system. We used to have a 96 LT 4X4 Tahoe that still used the good ole handle. That was a good Tahoe until some lady ran a red light So we ended up buying a new 04' Z71 Tahoe. The first year we had it some 4WD switch/sensor messed up making it pop in and out of 4WD. It worked fine for years until a few weeks ago. It got stuck in 4WD just like what your Tahoe is doing when I stuck it in 4WD Low. This was the first time I used 4WD low. Anyhow, I played with the switches and cut the truck on and off a few times and it finnaly dis-engauged. The 4WD system has been fine since but the fuel pump took a dump a few days ago lol
BoostJunkE is offline   Reply With Quote
Old 07-24-2008, 07:25 AM   #3
fletch57
Tahoeforum Newcomer
fletch57's Avatar
I purchased a brand new dash mounted switch from a local dealer, the LED's will light-up when the key is turned on but go off when it starts running. It does not indicate what is engaged on the switch, no light on the switch. I tried disconnecting the battery and that did not work! Is there something I can do?
Old 07-25-2008, 12:38 AM   #4
96ProCompTahoe
96ProCompTahoe's Avatar
96ProCompTahoe is on a distinguished road
Default
theres a switch on the transfer case that actually tells it what to do that sometimes go out, leaving you high and dry.
luckily mines not screwed up on me yet, but then again i have only used it a handful of times.
96ProCompTahoe is offline   Reply With Quote
Old 07-26-2008, 09:55 PM   #5
fletch57
Tahoeforum Newcomer
fletch57's Avatar
Default Service 4wd Problelm
What is the name of that switch, is it expensive, is it difficult to replace?
Old 08-12-2008, 03:55 PM   #6
fletch57
Tahoeforum Newcomer
fletch57's Avatar
Default
I finally found out what the problem was.
The transfer case encoder motor was bad, I already had it repaired at a local dealer. $$$$$
Thanks to everyones input and the information that was provided here.:cool2:
Fletch57
Old 08-14-2008, 03:01 AM   #7
NOKUY
NOKUY's Avatar
NOKUY is on a distinguished road
Default
oops
NOKUY is offline   Reply With Quote
Old 08-14-2008, 03:02 AM   #8
NOKUY
NOKUY's Avatar
Default
Anyone know if this encoder is the problem in my case... '98 Yukon w/ buttons on dash to engage 4x4. The 2HI is lit currently as it should be. However when I try to go into 4x4 and press 4HI... Nothing happens. 4LO and nothing happens either. And if so how easy is the encoder to install? See them on eBay
Old 08-14-2008, 08:45 AM   #9
fletch57
Tahoeforum Newcomer
fletch57's Avatar
Default
Quote:
I would suggest this, go to one of your local chevy dealers and have them diagnose the problem (it cost me $85), they should be able to tell you what part is defective.
Old 08-16-2008, 01:36 AM   #10
T-Bagg
T-Bagg's Avatar
T-Bagg is on a distinguished road
Default
I had a similar problem. All the lights out on my '98. Found out on one of my expeditions into a local mud pit, a rock tore through all the wires into the motor. Found a baseball size rock up in the skid plate, probably the assailant. Spliced 'em back together and problem solved
T-Bagg is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
