2017 Tahoe Premier Wireless Charging Upgrade?
2014TahoeLT
Oxford MI
I purchased a 2017 Tahoe Premier. My iPhone X will not charge on the wireless charger since the truck was built before my phone was designed and released to the public. Is there a wireless charging module upgrade that I can purchase and install so my iPhone X will charge?
I assume the 2019 Tahoe's will charge the iPhone X so again, I assume I could purchase that module but these are all assumptions. Any comments would be appreciated.
Tahoe2017
Texas
wireless charging is wireless charging, your iphone will not charge because the Tahoe uses a single loop(cheap) charge coil, has to exactly in the sweet spot and has to be closer to the back of your phone, GM charging pad is about 1/8" thick, remove this cover and replace with something thinner, remove /cut rubber pad to allow your phone to to fit.
