Okay so I have a 03 tahoe lt. It's the awd model. I installed 3 inch torsion key leveling kit. And the truck began to shift left to right under acceleration and my steering wheel turns by itself when throttling or letting off of the throttle. I've replaced upper and lower control arms. Ball joints. Wheel bearings. Tie rods. Sway bar end links. And still no fix. So I finally just yanked the awd t case and swapped a 4x4 one out and pulled the axles so its 2wd. The problem is alot better but still there slightly. So what does this sound like?
