Hey guys,
I will try and keep this short. I have read quite a few threads to attempt to solve my problem without posting, to no avail.
My wife has an '09 Tahoe that recently began blowing only warm air up front with slightly cooler air in the rear when all set on high AC. The fans are blowing strong and are fairly clean and undamaged, no seen issues with the blend doors as all selections correspond with what is selected, bought some AC Pro with a gauge that read around 52 pounds obviously on the low press port, when the AC is on, the compressor clutch engages beautifully...
So obviously I have an issue. My questions and info to all you gracious professionals...
1) For a 2009 Tahoe, is a reading of 52 on the low port indicative of over pressurization? And would that cause warm air with AC? I did not add any refrigerant after seeing that. When the AC is turned off, the reading spikes past the "red" and "pegs out". Is that normal? I have never serviced or messed with this AC system as we have never had any issues. It has always blown so cold, you needed a Parka. Obviously I am ignorant on this topic. I did notice that on the line with the larger port (I'm assuming the high pressure port), with the AC running, the line from the port back toward the firewall was ice cold and just before the line reaches the port, it's significantly hot (right past the connection of this main line). Is that normal?
2) Here is an event preceding the problem. 2 weeks ago, we took a trip to Gulf Shores AL from Ft Worth Texas and about 3/4 of the way, on the passenger side, under the dash, water/condensation began dripping on my wife's feet (A drop or two every 15-30 seconds) and the carpet eventually became damp. Upon some hard turns, it poured out from under there. It was not raining and the water was ice cold. This has been happening intermittently since that trip. Is this a common problem? We've never noticed this before. Indicative of a clogged line? :shrug:
3) The air began to do this 2 days ago.
Again fellas, I've read through a lot of material here and I am still lost. I'm kind of partial to not using dealerships because my @$$hole still hurts from all the times I've been bent over by those guys and frankly I don't really have the time. If I can get away with a potentially simple fix, that would be awesome!
I absolutely appreciate all your guys' help and comments!
Thank you.
Thank you.
