2010 Trans issue
highway903
I have a 2010 with 120,000. A few weeks ago the trans had no forward when stopped at a light. Shut it off for a few minutes and was fine when started back up. Worked for a day or so and same thing. Replaced the TCM, new filter and fluid. Had it programmed and was fine for 2 days.
Now it either does the same thing or when you start out it revs like it’s in neutral then bangs into gear. I’m frustrated!!!! Thanks for the help in advance
highway903
I think I finally figured it out. The #1 check ball in the valve body was worn down to about half of its original size. Cheap easy fix. Just wish I figured it out before spending the money on the TCM!!
Marcelo Cerda
Can you post more information on said "#1 check ball in the valve body" I think I'm having the exact same problem...
Thanks in advance.
