2019 Tahoe infotainment issues
rickcott
Member
Florence, SC
I have a 2019 Chev Tahoe with the Infotainment system. On every power up I get the exact message
"Application error", then "the application is having trouble loading, please try again later".
Well - "later" never happens. I press "close app" and mush on. No hint as to which application is the culprit.
I would appreciate any input.
Thanks
Shaggy
Administrator
On the 2019s that's usually one of the built in connected apps (Marketplace, weather and the like) trying to load at startup when the truck's data connection or OnStar plan has lapsed. First thing I'd try is holding the radio power button for around 10 seconds to force a reboot, and if it still pops up go into Settings and do a factory reset on the radio (you'll have to re-pair your phone after).
If it survives both of those the dealer can reflash the radio, and it's worth asking if there's a newer software update for it. Is your OnStar or Wi-Fi hotspot plan still active?
