Vista Cruiser 69
Guys,
the voltmeter suggest me millions of charging Volts, display says 16V but it is 14V, actually. Regardless how many buttons I press, all heater fans and stuff it stands like a president at real 14V even on idle. Which makes me think the generator can't be that bad....
Now, if my wife hasn't moved it for a day or so, now as winter is starting the crank rev is fairly low and it does not sound as it should when you turn the key. He fires up and all - but you can hear it becomes a close thing. If you drove it for 20 minutes and even switched all things on which our wifes tend to when its cold - it does no harm. You make your shopping trips and it always cranks well when turning key.
This makes me think I got a secret consumer stealing energy over time.
Putting an Amperemeter between battery and disconnected cable:
starts up to 1.7 A for 5 sec
stays on 1.5 A for 30 sec
stays at 1 A and does not seem to go down further
Well, 1 A = 12 Watt - which does not sound much but over time it sucks. There is a power lock waiting for a signal and not sure what else is on idle but snipping some energy. There is no Hifi oomph-oomph stuff installed, all stock Tahoe 2001 LT.
Does someone have an idea how high such an energy flow is or should be if the car was completely shut down? I considered this good old "fuse in and out and watch if light goes out" thingy - but times when we had 5 to 10 fuses are over!!!
And - befor some smart arse asks if I considerd the engine compartment lamp
when testing Amperes - yes, i did
Thanks for soem thoughts.
Replaced the battery as short term solution some minutes ago but one with standard pole design - aarrgghhh! Took me hours to convert from this GM side screw type, and then plus and minus completely other way round
