Biggest and Best Tires on Tahoe?
jakelsu777
I just got a 2005 z71 tahoe and I was wondering which would be the biggest tires i could run on it. I already have a 2 inch skyjacker leveling kit and i would like to know which sizes would fit. Also, I was wondering what would be the best type of tire if I spend weekdays on concrete/asphalt but weekends offroad with some areas that are very muddy. Thanks for all suggestions!:D
fco_gonzo
maybe up to 33's anything bigger you'll need a suspension lift. I would also recommend an all terrain tire. my personal favorite, BFGoodrich.
Zed 71
From another forum (older model - 2006 and lower):
The stockers are 265/70/17's (31.8").
The first oversize is 285/70/17's (33") which most Z's can handle without touching a thing. You might want to crank up the stock keys.
The second oversize is 295/70/17's (33.5") which will require Ford Keys, perhaps rear spacers and a little trimming
The third oversize is 305/70/17's (34") which will require spacers, Ford Keys adjusted to level, and I would plan on a good amount a trimming.
Anything over that requires Body Lifts and beyond.
