Chevy Transmissions
JimCee
I know 4 others with Tahoes or Suburbans that have had to get new transmissions because of complete failure. Anyone else with this problem? I had to pay because Chevy would not cover warranty that was expired by 4000 miles. :mad: I have been told that this is a common problem for these SUV's. Chevy denies it. What's your story??
mightymouse
Waynesville, MO
Hauling heavy loads can shorten the transmission's lifespan.
The #1 cause of transmission failure is heat.
If you plan to tow often, an aftermarket trans cooler is the way to go.
Yuke2K
Rural Littleton, CO
X2 on this, for sure. Heavy duty usage requires a little bit of heavy-duty retrofitting. Oil and trans coolers will help dramatically. Conversely, those who just use their trucks for the occasional haul or offroad will probably not have too many issues. My 00 Yuke has 84K miles on it and it runs fine, shifts great. My father in law's 02 Suburban has over 150K, and runs like the day it came off of the assembly line. Go figure.
If you haul or hard-use your truck, get a pretty decent sized trans cooler, but have it PROFESSIONALLY installed. Trans heat is the number one killer, but no trans fluid comes in a close second - which is exactly what you'll end up with if one of those cooler lines comes loose and dumps your fluid everywhere.
