I put one on from dashskin.com about a month ago. It's holding up fine. Some people say they're cheesey but I disagree. They look a heluva lot better than the cracked up stock dashes. Make sure you put a ton more adhesive on than it calls for in the directions. Otherwise you'll get a lot of spots that are glued down and will rattle. Also, don't put weights directly on the dash to weigh it down when glue is drying. It will take off dash paint when you remove them. Cover the pillars with blue tape to prevent scarring. I think you'll really like the dashskin.
