So I just did the DJM Free travel mod that they mention on their website and the one everyine talks about here. All I have to say is it's not as easy as they say it is.
A couple of things to know:
1. on the drivers side you are so close to the gas tank that you either risk cutting it or drop the tank. Or stop short and break the rest off (thats what I did). There is no chance of you getting a cut off wheel up in there.
2. cutting the inside of the passenger side is impossible to get your head and a helmet up there. So your cut aint gonna look pretty.
3. although they recommend that you use a plasma, I think it would be almost impossible if you don't.
4. Oh and there is no mention of dropping the spare tire. A MUST!
5. I did this all on the floor and not on a lift. Which means the hole that had to be drilled, I had to use a right angle drill so that I could get it in there straight enough.
All that said, you do get a lot more clearence and in all it only took about 2 hours (with plasma cutter). I am not sure how it is going to ride yet, when I was putting my wheels back on I found a nail in one. So I have to get that fixed but I will let you know.
