wingnut24fan
I removed the dash trim panel so I could remove the stereo. Once I had the trim panel removed I thought hat I'd remove the headlight switch as the dash lights would not work unless I moved the dimmer switch to a certain position. Once I touched the headlight switch, the door chime started to sound and the security light flashed. The only way I can stop the door chime from sounding is to remove the headlight switch. I tired disconnecting the battery thinking that it might reset this, but it didn't work. The only way is to disconnect the headlight switch. Has anyone else had this happen? Does anyone know how to fix this issue? Thanks in advance!
