Product Description
The HydroFoamer's unique injection concept mixes the proper amount of concentrate with both air and water to produce a thick, rich foam for longer soak time.
HydroFoamers eliminate the time and hassle of manually mixing concentrates, which not only increases labor productivity, but also increases concentrate performance because the solutions are consistently mixed as directed by the manufacturer. Since concentrates are mixed only as they're applied, they are fresh and will perform at peak power, and waste is minimized.
Application of diluted solution with the HydroFoamer hose-end proportioners is easy. On and off functions are finger-tip controlled using a trigger on the spray nozzle. To rinse, the concentrate container is disconnected using an easy-to operate quick coupler, which is designed to allow either a full width spray or powerful jet stream when rinsing. This range of control helps personnel put the solution only where it's wanted.
