Big Tap
After many months of setbacks and waiting, it's finally time to buy some paint for my Tahoe. Originally I was going to go back with the facotry gray, but my painter offered to do a color change in the jams and everything, free of charge. Not one to pass up an opportunity like this, I'm now trying to decide which color to choose.
I had some test panels done and had started to settle on a custom blue mix of Toyota Nautical Blue Pearl with a bit of added blue pearl and flake. The paint looked great; think factory Chevy blue with a darker translucent finish that popped with the pearl. The thing that scares me away from this is trying to fix it later should something bad happen to the paint. With it being a custom mix, this could create problems. The other thing is that it looks a lot like a stock color to me and I don't know if I want to go to the trouble of shooting a custom color if it's going to look close to factory.
That leads me to where I am now. I'm starting to lean towards two factory colors that I'm considering. Since the facotry gray grew on me a bit, as well as the blue, I have thought about going with a compromise of the two. I think it has a nice color to it and gives a subtle custom touch since no other Tahoe will have the same color paint.
The first is a BMW Toledo Blue Metallic (TBM). The Second is a Chrysler Modern Blue Pearl (MBP).
Modern Blue Pearl
They are similar colors in normal light, with the MBP having a slightly darker appearance than the TBM. The MBP also has a larger silver flake in it that is visible in normal light. In the sun, the TBM really pops and has more of a steel blue look to it with very fine green and silver flake. In the sun, I would say that the TMB has more of a greenish blue hue, while the MBP has more of a grayish blue hue. Both are great colors from what I can tell in the paint book.
As you can tell, I've put a LOT of thought into this. The pictures don't really do either color justice, but at least its a reference point. Any help would be appreciated as I'm probably going to buy paint this week. Thanks!
Modern Blue Pearl
