Interfacing aftermarket HU with factory BU cam
For those of you with the factory back-up camera and want to install a new head unit, here are the pins you need to connect the factory bu cam to the new unit:
Pin 6 and 7 on the brown plug are the feed wires.
Pin 6 is signal and pin 7 is ground.
Hope this little bit of info helps.
