Making exhaust louder
xTAHOEx
Alabama
Im wanting to make my exhaust louder without straight pipeing it. Right now its true dual with cats. Any info. would be helpful.
clkelley
Moderator
Galax, Virginia
Welcome to the neighborhood.
What year model truck do you have. On a vehicle with catalytic converters you can't just straight pipe it from the manifolds, you can behind the cats thought. The easiest way to do this, (and you may want to check local laws because removing the muffler may get you in trouble.) but you can take it to a muffler shop and have them remove the muffler weld in a patch pipe. Done, louder exhaust.
Now, for better sound that you would probably like, but that wouldn't have annoying drone at highway speeds, etc Putting a Magnaflow in place of the stock set up would give you aggressive sound under wide open throttle without driving you absolutely nuts when cruising down the highway.
Hope this helps a little
xTAHOEx
Alabama
Its a 1996 2 door tahoe and it was stock dual into the muffler but came out one pipe so I had it cut off just before the muffler and ran out. It originally had two cats after it got about a foot from the manifolds. Also were im at the cops dont really care if its legal as long as your not hammering it to make it loud.
clkelley
Moderator
Galax, Virginia
You should be ok as long as you don't get rid of the cats. If you did that you would wind up with the truck not running just right.
