1999 Tahoe, 4x4. Stock..
Everything is unbolted, disconnected, Crossmember is out of the way, Transfer case is disconnected and slide as far back as I can get and keep it there.
So, everything is ready to drop.. but for the life of me, get the Trans to clear the Transfer case (trans output shaft is still inside the Transfer case some) and the bell house to clear the fly wheel.. I don't have a manual nor access to allData for any more procedures..
What is the trick here guys.. I don't want to remove the Torque arm crossmembe setup.. which is keeping the transfer case from moving completely out of the way. What most be removed, moved or muscled out of the way ?
Thanks in advanced..
BC
BC
