New guy with an old Tahoe
Webster
Member
Colorado
I have a '09 Chevy Tahoe LTZ, FWD, with a 5.3L engine, & 176,000 miles. Its oil changes have been on schedule using Valvoline 5-30 full synthetic. Vehicle has had drive train maintenance and some front end work, a few years ago. It's never been in a crash. Last Winter I replaced the oil pressure sensor. There was no leakage around it. The vehicle has always run great. We are in our 70's and never abuse a vehicle. Last Saturday, after parking on a side street for two hours, I drove the 15 miles home with no issues. Sunday morning I discovered a large pool of motor oil underneath the rear of the engine. I inspected the front & both sides as best as I could without removing anything, and using an endoscopic camera. Nothing found. Next I crawled underneath, camera and lights, inspecting the rear of the engine. Oil covers the driver's side of the bottom of the engine, but I could not see a likely source. When I run the engine oil pressure is normal, fluctuating as engine speed rises and slows. I did not run the engine while I was under it. I drained the oil today, about 4 qts of the 6. My next move will be to remove the top of engine parts to gain a better view of the oil pressure sensor. But again, all the oil I can see is on the driver's side, and below the middle of the engine. My question: Is there anything that could have caused this that commonly occurred on these vehicles? Thanks!
Webster
Member
Colorado
Inspected oil pressure sending unit, no apparent leaks. Will tow it to a shop tomorrow. Still looking for an obvious cause that an old shade tree could fix. Ideas anyone?
Mbdarkhorse
Member
PA
Could be a rear main seal? Did you check the sending unit with the vehicle running?
Webster
Member
Colorado
Sorry for the unbelievably slow response. I'm a cancer survivor with some residual problems from chem. And of course, I/we added a bedroom & bath in the basement for our son's family to use when the visit at Christmas. As my bride of 52+ years would, all excuses, not valid reasons. Back to the Tahoe, no, I have not checked under the engine while it is running. Strangely, there is not one drop on the floor in the garage. However, the last oil change had approximately 3 quarts of oil in the pan when I changed the oil. It has recently developed a Level 1 emissions leak. The last time it had this, replacing the gas cap solved the issue. This time it did not. So I'm also chasing that problem. Any ideas are appreciated. It may be time to trade it in...
