What's the biggest tire I can put on my 04 base Tahoe without having to put a lift on it? I believe I can torque the tension bars to get some extra clearance. I was thinking 285/16s nitto trail grapplers would work?
I figured I would. Have y'all had any trouble with the instrument panel? Mine only works sometimes. Not sure if I should trust the check engine light or not!
The whole thing only works sometimes or jjust the guages. Alot theses years had problems with the guages not working. I ha d a couple guages not working and I just replaced it with an escalade instrument panel. Your computer turns the check engine light on so its probably coming on for a reason.
McKinney tx, the gauges only work sometimes. The check engine light comes on for a day or so then shuts off for a couple. I looked into changing out the panel but it's a pretty penny. You get that escalade panel from scrap yard?
