no spark no start
Discussion in 'General Tahoe/Yukon Discussion Forum' started by guadapapa, May 8, 2019.
  1. guadapapa
    guadapapa New Member
    May 8, 2019
    Hello all,
    I have a 96 chevy Tahoe,
    I got the car for free a year ago. was told it needed a fuel pump. did that job. couldn't get the car to start. I noticed the car wasn't getting any spark. but finally got it to start. car sounded perfect, I left it on for a half hour. by next day the car wouldn't start again. I wasn't able to get it fired up again for a couple more months and same cycle happened again. left it on for a half hour, drove it around, sounded perfect. by next day wouldn't start again. Engine turns but no spark.
    I appreciate the advice.
  2. east302
    east302 Full Access Member
    93
    Jan 1, 2008
  3. Bigthangs65
    Bigthangs65 New Member
    Jul 17, 2019
    Orange County, CA
    Make sure the coil is in spec, run a ohm test on the coil use the Chilton manual for instructions. Also is the ignition module burnt out? It may be a bad module that is not sending the right signal to the coil to start your engine. Remove cap and rotor and inspect, a bad rotor will also cause this problem a corroded cap may also be a culprit. These trucks are known for bad ignition systems. I have replace all of my ignition system (distributor, coil, module) no starting problems since.
